what happens if DC blocking capacitors is removed - Page 4 - diyAudio
Old 9th November 2012, 01:24 PM   #31
Do you want to be known as a misguided guesser or a Member who makes informed decisions.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th November 2012, 01:35 PM   #32
Robert Kesh's Avatar
That is not the issue at question.
Guessers, and the wise, can be both rude and polite.
Old 9th November 2012, 02:03 PM   #33
jrenkin is offline jrenkin  United States
Originally Posted by Igla View Post
My LM3875: no caps at the input and no feedback caps....I have about 30mV DC at the output.....6 years and still running and no damage to the loudspeakers. My DAC has output caps (TDA1543/CS8412) so no need for another caps at the amp input.
The sound is definitely better without caps no matter how expensive they are.
I never understand this. Isn't your DAC output cap just the same as an input cap? You do have caps in the signal path, just not ones you put there in that piece of equipment. You just didn't add another cap.
Old 9th November 2012, 02:12 PM   #34
Yes, Jr.
He has a DC blocking cap and the signal is passing through it.
To state he has no coupling cap is a nonsense.
I did not respond initially since I was not sure if he was just trying to "wind me up".
But, now I see that at least one other is aware of his fallacious argument.
regards Andrew T.
Old 9th November 2012, 03:35 PM   #35
Igla is offline Igla  Slovenia
Sorry, I didn't want to wind anyone up.
About input caps:
We are speaking about input caps in our gainclones or chip amps. So, I would say there is no need for input caps in the chip amp because all CD players and other commercial available sources have output caps to block DC or they block DC some other way.
When I removed input caps from my gainclone I never looked back.
And about caps in negative feedback to ground:
I don't have caps in the feedback loop to ground because I have discovered, that those caps have a large influence on the sound. Yes, without those caps you will have some amount of DC voltage at the output of the amp. Still, I never had DC offset larger then about 50mV on all my LM1875 and LM3875 and OPA549 amps.
Old 9th November 2012, 04:25 PM   #36
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Andrew, you are being very emotional and need to chill out. I can easily post data on LM3875 and LM3886 chips (as well as the OPA541s which have near-zero DC offset) to show how either with or without DC blocking capacitors the change in DC offset is small.
You are just embarrassing yourself, Andrew, so I will do you a favor and not embarrass you further.
Old 9th November 2012, 04:43 PM   #37
R is guessing by swapping in and out components.
If R would just do some numbers, he could home in on solving the missing bass without having to guess.
You've been telling him that for 3 pages, Andrew. Calculating poles is the basic of basics, but he would rather listen to woo.
30 seconds of quality time with a calculator would answer his question.
I guess I wasted all that time and money on engineering school. I could have just talked to a couple of kids with soldering irons and learned everything I need to know.
Old 9th November 2012, 04:48 PM   #38
Near zero offset with a test signal. Real world signals are not perfectly symmetrical. You could do some measurements and find that out for yourelf.
Using a mathematical model, the integral of a sine wave (or two sine waves for IM measurement) is zero. (Not the integral of the absolute value!) The integral of a real world musical signal is not zero.
What does the integral of the signal give us? The theoretical DC offset of a "perfect" amplifier with zero quiescent DC offset.
Old 9th November 2012, 05:02 PM   #39
with the input capacitor 1uf and series resistance of 237 ohms
i got the RC time constant as
.24 milli seconds for R = 237 ohms and C = 1uf
Old 9th November 2012, 05:32 PM   #40
i tired adding two 1uf/50v silmic back to back to make bipolar cap so the resultant is .5uf in parallel with 1uf styroflex. I got the bass properly as expected and have all the mids and low mids and high bass are very well rounded and still the highs are very well extended and even the vocals are not overtoned...
I removed the styroflex from the loop and tested only with the silmics there was complete loss of the upper mids and highs... or I just got all the bass freq added..
then added the styroflex on top of it gave the mids and upper freq extension and open sound...
strange thing is that why I couldnt get this even after adding two 1 uf styroflex in parallel... which now got with just .5uf of silmics in signal cap... i was just a try but was giving decent results....
Andrew what can be done with RC time constant? like i have posted in the above reply...
can i get back the bass with the same styroflex caps? I have total 26 of them with me if you can tell me what value to be used it would be great... as I have replied in the earlier post reg the time constant...
DC Blocking Capacitors dome406 Chip Amps 18 4th May 2011 05:07 PM
Hypex SMPS DC Error detection and DC blocking cap bypass MaartenJ Class D 4 7th January 2011 10:58 AM
DC blocking cap in feedback path or DC servo? roender Solid State 27 19th September 2007 09:40 AM
Favorite film capacitors for DC blocking? The Peasant Parts 18 1st December 2006 04:37 PM
DC blocking capacitors soundNERD Chip Amps 4 25th October 2005 01:36 AM
Copyright 1999-2017 diyAudio
