what happens if DC blocking capacitors is removed - Page 3 - diyAudio
Old 9th November 2012, 04:35 AM   #21
No challanges for the metallized polypropylene.
Gajanan Phadte
Old 9th November 2012, 05:58 AM   #22
I tried a new config 1uf styroflex 50v || 1uf polysterfilm || 8600pf polystyrene 63v cap and now the bass is tighter and still mids and highs are well balanced much better than before (1uf styroflex cap...)...
thinking of other configurations...
Old 9th November 2012, 06:20 AM   #23
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Originally Posted by AndrewT View Post
If you don't know this then you should not be considering this modification.
You are behaving like a foolish child, who has no appreciation of danger and takes risks because they have no previous experience to fall back on. The not so foolish child listens to their parents.
Jeez Andrew, the OP asked a very fair question. You are overreacting.
In regards to the popular LM3875 and LM3886 chips, there will be 40-120mV DC at the output regardless of filtering capacitors at the input or having the feedback filtering capacitor. This is a bit high compared to most amps and may affect the sound of the speaker, but it will not damage the speaker.
Old 9th November 2012, 07:16 AM   #24
palstanturhin's Avatar
In what frequency do you have the low frequency cut off?
Both at the input and at the feedback loop?
Andrew asked you this...
And im also curious about it...
Old 9th November 2012, 07:32 AM   #25
anything less than 150 there is definitely more than 3db cuttoff... i cant hear the upper bass or lower mids... no warmth in male voice...
Old 9th November 2012, 08:26 AM   #26
And the resistor in parallel with your input source? = Your input impedance therefore is?
Old 9th November 2012, 12:42 PM   #27
Originally Posted by cotdt View Post
...............In regards to the popular LM3875 and LM3886 chips, there will be 40-120mV DC at the output regardless of filtering capacitors at the input or having the feedback filtering capacitor.
This is the typical rubbish posted by ill-informed Members.
Take your version of physics to another Forum.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th November 2012, 12:45 PM   #28
R is guessing by swapping in and out components.
If R would just do some numbers, he could home in on solving the missing bass without having to guess.
Eg, if we/he knows that the input filter is not rolling off the bass early AND if we/he knows that the NFB capacitor has virtually no AC voltage across it (by being sufficiently higher RC) then we/he knows it is not the filter frequency that is at fault. We/he knows to look elsewhere.
At the moment neither he nor us have a clue where to look because R won't state what the RCs are in the amplifier.
regards Andrew T.
Old 9th November 2012, 02:11 PM   #29
Igla is offline Igla  Slovenia
My LM3875: no caps at the input and no feedback caps....I have about 30mV DC at the output.....6 years and still running and no damage to the loudspeakers. My DAC has output caps (TDA1543/CS8412) so no need for another caps at the amp input.
The sound is definitely better without caps no matter how expensive they are.
Old 9th November 2012, 02:21 PM   #30
Master AndrewT; there is no need to be rude. After all, we are talking about lousy chip amps and not about something your life depends on, right?
DC Blocking Capacitors dome406 Chip Amps 18 4th May 2011 06:07 PM
Hypex SMPS DC Error detection and DC blocking cap bypass MaartenJ Class D 4 7th January 2011 11:58 AM
DC blocking cap in feedback path or DC servo? roender Solid State 27 19th September 2007 10:40 AM
Favorite film capacitors for DC blocking? The Peasant Parts 18 1st December 2006 05:37 PM
DC blocking capacitors soundNERD Chip Amps 4 25th October 2005 02:36 AM
Copyright 1999-2017 diyAudio
