IC Amp for Multimedia Speakers
Old 7th November 2012, 12:36 AM   #1
Vilic Gabrielia is offline Vilic Gabrielia  Canada
Default IC Amp for Multimedia Speakers
Hello, Could you recommend an IC amp for small multimedia speakers with following spects:
External Power Supply
Must fit inside the speaker cabinet of 4.5 x 6.5 x 11.5 in Internal Dim.
Mono for each Speaker
Low Dist <0.5 @ full power
Min 12W clean RMS power
and of course good sound.
Thank you for your input
Vilic
Old 7th November 2012, 04:18 AM   #2
DUG is offline DUG  Canada
Depend on how adventurous you are.
TPA3118D2DAP class D... http://www.ti.com/lit/ds/symlink/tpa3118d2.pdf
Or any of the chip amps mentioned on this forum.
Amplifier kits or modules from Madisound or Parts Express.
You are in the GTA...try Sayal if there is one close to you...they have amplifier kits in some of their stores.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 7th November 2012, 06:10 AM   #3
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
IC: TDA2030
Old 7th November 2012, 06:47 AM   #4
sofaspud is offline sofaspud  United States
sofaspud's Avatar
The LM1875 has tons of support and will provide >12W with a supply of 18V or more, into 8Ω.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 7th November 2012, 11:54 AM   #5
R.I.P.
There are hundreds that can be used.
Download the data sheets of the National chipamps for starters.
Read the Threads discussing build recommendations.
regards Andrew T.
Old 7th November 2012, 04:25 PM   #6
johnr66 is offline johnr66  United States
TDA2050 with dual rail DC supply based on the Radio Shack CT 25.2V 2A transformer will output 14 watts pre clipping into 4 Ohms or 10w into 8, both channels driven continuous sine wave. LM1875, TDA2040 or TDA2030A will also work, but with slightly less output.
Buy your ICs from a place like DigiKey. Forget eBay. All I tried were fakes.
IC Amp for Multimedia SpeakersHide this!Advertise here!
TDA7265 for multimedia speakers pra3718 Chip Amps 51 10th January 2013 12:23 PM
IC FS/FT Beveridge Model 2 speakers studeb Swap Meet 3 23rd July 2010 02:41 AM
IC: Energy C-1 speakers xstephanx Swap Meet 1 11th July 2006 03:28 PM
Powered Multimedia Speakers with DSP bimbla Chip Amps 1 18th January 2006 01:35 PM
multimedia powered speakers... driver match? trespasser_guy Multi-Way 0 16th May 2003 05:38 PM
