Old 5th November 2012, 12:48 AM   #1
uncle_leon's Avatar
Default Minimalist LM3875 + PLLXO = what input impedance?
Hello, I have a question that is probably trivial, but I have not been able to find a simple answer, and all this impedance business has always rather baffled me... I am trying to find out what is the input impedance of an LM3875 chip?
The amp I am using at the moment is in the attached picture. It is a complete schematic of everything that sits between the DAC output and the input of my speakers. As you can see, it is just a Gainclone with a passive attenuator, only stripped of all parts that are not necessary for stable operation: there are no input caps, no input resistors, no smoothing caps in the PSU etc. (not even fuses ).
The 300R resistor is swappable, and serves two purposes: firstly to regulate volume (I change it for a different value when I need to adjust volume), and secondly to tie the input to the ground.
I have recently been considering a "passive line-level crossover". The idea seems sound, and what's more, the values of components required seem to fall into the sort of range I could make myself.
So I did a bit of reading, and I found this article:
Crossove_Design
and also this "calculator":
TLS.org | Passive Line-Level Crossover
The equations are simple, but they need "input impedance". As I would (obviously) like to insert the PLLXO after my volume control resistors, the question is, what is my input impedance at that point? The datasheet does not mention this, so I am guessing it is something obvious, like zero... I just want to make sure.
Studio Zèy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
PLLXO input impedance when doubling amps? SAC Digital Line Level 3 15th October 2012 08:09 PM
different gain levels and a PLLXO´s impedance poldus Analog Line Level 5 24th March 2011 07:13 PM
help with passive line level crossover PLLXO for 33K impedance amps Daveis Analog Line Level 1 14th December 2008 08:12 PM
Using phono input with PLLXO mashaffer Subwoofers 0 13th August 2007 11:36 PM
input impedance LM3875 Diy martin Chip Amps 7 1st July 2007 11:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
