LM1876 - Page 3 - diyAudio
Old 11th November 2012, 08:08 AM   #21
pra3718 is offline pra3718  India
Accepted solutions.
1) Ground Pin 5,10 shifted to power ground.
2) Zobel shifted to decoupling ground.
3) RF makes low input voltage, So instead of using RF I put 220pf between input pins. Pls. describe RF & 220pf (between input pins) functionality.
4) Lower value resistor sounds good to me. but it cut low bass. with the same value resister Post # 17 I can fit 2.2uf input cap. Anyway, now I have selected standard value resistor.
5) I am using 4R speakers and power supply voltage is 20VDC(+/-) I read datasheet and found if I increase supply voltage it produce heat instead of producing output-power. So I can get 22W of continuous average output power with less than 0.1%THD.
Old 11th November 2012, 08:24 AM   #22
Post # 21, is accepted solution, One confusion is there, Rin (47K) is important when Amp played without crossover. But not necessary with active crossover. Amp sounds good without those. WHY ?
Old 11th November 2012, 08:39 AM   #23
Robert Kesh's Avatar
Some of your caps are in backwards.
Old 11th November 2012, 08:54 AM   #24
Sorry, not got it.
Old 11th November 2012, 12:17 PM   #25
AndrewT is online now AndrewT  Scotland
I don't like this solution. It increases the risk of amplifier misbehaviour, due to adding capacitance to the -IN Pin
Power supply or feedback?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th November 2012, 07:03 PM   #26
I'm sure if you look at the pcb and the amended pcb, both on this page, you can work it out for yourself.
Old 12th November 2012, 02:47 PM   #27
Todays Job, RF added 220pf and between input pins removed.
Old 15th November 2012, 06:56 AM   #28
Default how to wire dual mono lm1876
Confusing part is 1R resister join clear & dirty ground. Configurable at Chip-amp or power supply. I tried my own way.... Pls comment.
Old 25th November 2012, 12:37 PM   #29
One channel Left-only build. Sounds good. There is not turn-on-off Noise detected when source not connected. Turn ON/OFF Noise is there when USB-DAC (Source) connected. So Noise coming from DAC ?
Old 25th November 2012, 01:20 PM   #30
How about adding diodes across the 1r and across the DC blocking cap/s in the NFB and across the the power rails via PG and across the power rails via output/s rail?
Remove that loop in the signal routing. The Signal Return is half a mile from the signal hot !!!!!!!
regards Andrew T.
LM1876 Eagle file Audio Bliss Chip Amps 2 20th September 2011 11:16 AM
Lm1876 Bone Chip Amps 8 18th February 2011 03:32 PM
LM1876 shematic hamedfazelm Chip Amps 4 26th May 2010 01:59 PM
LM1876 power amplifier JozzaG Chip Amps 3 4th February 2010 02:23 PM
lm1876 fabpri Chip Amps 4 15th January 2004 01:22 PM
Copyright 1999-2017 diyAudio
