LM1876 - Page 2 - diyAudio
Old 9th November 2012, 06:23 AM   #11
pra3718 is offline pra3718  India
Must the LM1876 have both pins 2 and 15 connected?
Old 9th November 2012, 08:30 AM   #12
palstanturhin's Avatar
Yes I can see you have them both connected.
Must they be? Or can you use just one?
I really do not know this and im curious about it.
Old 9th November 2012, 08:53 AM   #13
Pin 2, 15 should be connected to +V, it depend on you how do you connect.
Old 9th November 2012, 09:59 AM   #14
OK,
if there is an alternative to choose from, either pin 2 or pin 15 connected.
Then I believe you have a possibility to make a much smaller PCB and realise Andrews advise in that.
Old 9th November 2012, 10:06 AM   #15
sofaspud's Avatar
Pin 2 is the Vcc connection for one amp, pin 15 is Vcc for the other. If you measure 0.00 ohms between the pins it may not make any difference, but you most likely have to connect both (because it won't be 0.00 ohms).
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 9th November 2012, 01:03 PM   #16
Robert Kesh's Avatar
Originally Posted by AndrewT View Post
But the 1876 only has one Vcc Pin.
This is the typical rubbish posted by ill-informed Members.
Take your version of pin outs to another Forum.
Oh you deleted the post. How unsporting!
Old 10th November 2012, 04:31 PM   #17
Another try
Old 10th November 2012, 04:34 PM   #18
You are on the right track/trace.
Instead of the Zobel coming to the front of the PCB. Could you take it straight back to the decoupling ground?
Ah! single sided stops that. How about a wire link?
RF filters?
Is Pin10 clean? I would take that to Power Ground, if there is a risk it could contaminate Signal Ground.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th November 2012, 04:47 PM   #19
Thanks,
Parts selection :
Cin = 1uf
Rin = 10k
Rb = 220r
Ri = 220r
Rf = 10k
Rsn = 4.7r
Csn = 0.1uf
Cs = 0.1uf
= 10uf
= 1000uf
Gain = 45
Old 10th November 2012, 04:52 PM   #20
Cin Rin @ 10ms will severely cut low bass and affect upper bass.
Gain at 45times would require only 440mVac for clipping of a 50W into 8ohms amplifier. Even lower (340mVac) for a 60W into 4ohms amplifier. Are your Sources that low in output?
regards Andrew T.
LM1876 Eagle file Audio Bliss Chip Amps 2 20th September 2011 11:16 AM
Lm1876 Bone Chip Amps 8 18th February 2011 03:32 PM
LM1876 shematic hamedfazelm Chip Amps 4 26th May 2010 01:59 PM
LM1876 power amplifier JozzaG Chip Amps 3 4th February 2010 02:23 PM
lm1876 fabpri Chip Amps 4 15th January 2004 01:22 PM
Copyright 1999-2017 diyAudio
