Discussions on Balenced Amplifers
Old 13th November 2003, 06:32 AM   #11
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Default Re: Re: Re: Discussions on Balenced Amplifers
Originally posted by Brett
A much better idea than most of the others presented.
Thanks. It's worked for me for quite a few years. Though it can be considerably more expensive than some of the others presented.
se
Old 13th November 2003, 07:26 AM   #12
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Ssm2142 / Ina134
Transformers are best, but....
The best non-transformer, non valve solution:
http://www.analog.com/Analog_Root/pr...SM2143,00.html
Old 13th November 2003, 07:31 AM   #13
theChris is offline theChris
Originally posted by Mad_K
This is one of the pages I read when making my bal. gainclone
I can't understand what all the fuzz is about. min. 45dB CMRR, and 0,00078dB signal imbalance (10 ohm SE output Z from source). Who needs higher performance than this for audio?
well, the circuit isn't balenced. while it is capable of canceling equal noise on both inputs, it is not capable of picking up the same noise on both inputs. if it were balenced, i would not be able to pick up all that hum on my crossover (which uses the circiut with less gain as an input buffer). i can pick up hum by moving the cables near a transformer.
if only it could be used for good, not evil...
Old 13th November 2003, 07:31 AM   #14
Brett is offline Brett
Brett's Avatar
Default Re: Ssm2142 / Ina134
se
You're welcome. The initial cost is an issue, but there's all the advantages the Tx's have, and providing you don't toast them, will hold their value well for later resale.
Well John, the 2142's had better have improves a lot since I last used them, because they sounded dire.
Old 13th November 2003, 07:51 AM   #15
Steve Eddy's Avatar
Default Re: Re: Ssm2142 / Ina134
Perhaps in the pro audio market. With the exception of transformer-based attenuators and MC step-ups, transformers are almost unheard of in high-end home audio.
se
Old 13th November 2003, 08:00 AM   #16
Brett's Avatar
Absolutely, but if you bought some of the Jensens and decided to sell them later, they would sell readily on ebay.
That's their misfortune then isn't it?
Old 13th November 2003, 08:36 AM   #17
Steve Eddy's Avatar
Let's watch:
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=4665
Hehehe. Naaaaaaah. Hey, if they're happy, I'm no one to argue.
se
Old 13th November 2003, 05:45 PM   #18
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
yep, a basic difference amp... very informative datasheet also
edit: was supposed to quote dhaen...
Mads K
Old 3rd January 2004, 05:07 PM   #19
greyhorse is offline greyhorse  Canada
The only input transformers that are mentioned in these forums seem to be ones specially designed for music (pro-fi, or hi-fi) use, and are thus fairly expensive.
Has anyone thought of using cheaper alternatives like those made by Tamura or Hammond? The following transformers from Tamura look interesting, but what do you guys think of them? Can anyone suggest a good circuit using one of these transformers for making a bridged amplifier?
On page 3:
http://dkc3.digikey.com/pdf/C041/1160-1165.pdf
Old 3rd January 2004, 07:25 PM   #20
just out of curiosity, how is that IC balenced. i agree that it is a difference amplifer, but i don't agree that it has equal input impedances. as i understand it, the idea is to have equal impeances to pick up equal noise then use a difference amplifer to cancel it out.
no one has been able to show me that this circuit is balenced with any input signal. it is balenced without a signal though, so i guess during silence - when noise could be heard - the noise rejection increases.
Discussions on Balenced AmplifersHide this!Advertise here!
Discussions about your favorite or DIYD/T-amp v-bro Class D 0 13th January 2009 09:37 AM
B&O Icepower Amplifers nautilus Swap Meet 8 19th December 2007 12:41 AM
Soundstream Amplifers Flyin11 Car Audio 4 19th October 2007 10:22 PM
Class D discussions mskeete Class D 16 19th March 2004 07:27 AM
Do opamps discussions also have to take place here? Bricolo Chip Amps 3 27th April 2003 09:39 PM
