Why are there only disastrous PCB Versions for TDA7293/TDA7294/LM3886 etc. available? - Page 4 - diyAudio
Old 18th April 2013, 02:23 PM   #31
nigelwright7557's Avatar
Originally Posted by s3tup View Post
Whoa!?!?
It's the reason the TDA could be better than the LM - it has SEPARATE input and output stage supply pins, which is great.
I wish the LM had these.
Its possible to get the output modulating the input if the output and input supplies are not seperated.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 18th April 2013, 07:22 PM   #32
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Whoa!?!?
Well, it "could" ... but since everybody uses them joined ... even the datasheet example , I stick to my opinion.
And anyway, even if that was the original idea, they still might have used contiguous pins, so both options are easy to choose.
As is, it unnecessarily messes with the PCB layout.
In both cases they have not 1 or 2 but 5 or 6 legs in the middle.
If course, *she* also thinks that crisscrossing those tracks is no big deal:
Old 18th April 2013, 08:00 PM   #33
s3tup's Avatar
That's a good reason to go double-layer PCBs and reconsider the tradeoffs of trace length, inductance and current loops.
danielwritesbac,
I hope you've forgot to put quotation marks across the "non-disaster" idiom
These eBay PCBs are Good examples of Bad Layout
The main, heaviest current path is between the output stage rails, TDA's output and GND pins of bypass caps. This region should be as small loop area as possible.
What do we see on eBay (and lots of other PCBs)? The supply comes 'round the left/right edges of the board. Huh.
Bypass caps, as close to the IC as possible? Nah, they are subminiature and placed at the farthest place possible - on the opposite corners of PCB.
They are laid out for:
- Small overall footprint
- Cool/simple connectors placement
- Smallest bypass caps, because they are pricey
Yet, i have to say, they did a Great Job on cost reduction front. 10$ for 50w of power, shipped?
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 18th April 2013, 10:17 PM   #34
[/IMG]
I don't join them !
It is wrong to just join them and that is lazy and cheap design.
Its the same with random earthing of a layout and then wondering why you get hum.
PCB designs is a bit of a black art and get it wrong and your audio sounds like !"!"$
Old 20th April 2013, 08:12 PM   #35
chriscam's Avatar
non disaster design
where solid state amplification is like photography, tubes are for painting. sometimes the best solution is to paint over a photograph.
Old 21st April 2013, 02:04 PM   #36
s3tup's Avatar
chriscam,
Your's PCB looks nice, especially given the restrictions of 3-channel design. What are the board dimensions? I'm thinking of something similar, but with 6 channels and 10x10cm PCB
But i may drop the 6-channel thing and go 3-4 channels if 6 won't fit.
There is a nice feature for multiway amplifiers - they don't need to be precise copies of each other - especially on power supplies. You can feed the most powerful channel with main large caps, and then feed the other channels with RC filter where R will limit the current and C would be calculated for the xover cutoff frequency. This way you get most of the power on the woofer, and delicate and clean supplies on mid/tweeter. Not to mention the reduced bypass cap sizes for mid/tweet section.
300Hz and 1ohm resistor = 680uF caps
2000Hz and 1ohm resistor = 100uF caps
These are tiny!
Old 22nd April 2013, 02:48 PM   #37
chriscam's Avatar
Thanks it's 100mm x 80mm, double layer with DC protection, 8000uF onboard buffer.
It's accompanied by a 3ch substractive 12dB xover, mfb correction & limiter in the same formfactor.
Old 25th April 2013, 07:53 AM   #38
chriscam's Avatar
Default project info
For those interested in schematics, the whole project is described over here, the only gotcha is that it's dutch an englisch versionis in the making
Old 25th April 2013, 12:37 PM   #39
JMFahey's Avatar
Hey!!! .... KILLER project!!!
So it's a modern upgrade for a **very** good and advanced Philips bookshelf speaker?
Cool!!!
Are you offering it here at DIY ?
It sure would raise a lot of interest.
But .... please do translate that assembly manual to English
No big problem with the Argentine version, I can ask for Maxima's help for that
Old 26th April 2013, 05:06 PM   #40
thejohn is offline thejohn  South Africa
Ditto! I do like the look of that amp board... If boards or Gerbers were available I'd definitely be interested. I's also currently using a Connex SPMS200QR with my 3886 amps but 3 channels on one pcb would certainly make the wiring less / easier / neater!
John
TDA7294 + Power Transistors AMP (TDA7293 to come also) dr frost dk Chip Amps 633 20th May 2017 06:31 PM
TDA7293/TDA7294 - by which commercial integrated Stereo Amps in use ? tiefbassuebertr Chip Amps 12 26th January 2015 11:43 AM
TDA7294 TDA7293 LM3668 Spice micijanus Chip Amps 2 17th August 2014 03:50 PM
Differences between TDA7293 and TDA7294???? Leolabs Chip Amps 1 22nd December 2006 10:12 AM
Copyright 1999-2017 diyAudio
