LM386 Distortion and White Noise ??
Hey all -
I feel like this thread might be applicable to more than just LM386 circuits, so bear with me...
I am building a (purposely lo-fi) amp based on the LM386. It is powered by a 10 V DC power supply that I put together. I am using the bare-bones layout from TI - using minimal gain of 20.
Schematic:
Here's my problem:
When there is no input to the amp, it is dead silent. When I plug in my iphone to my headphone --> line level converter, it is STILL silent. When I hit play, I get white noise and distorted music, no matter the volume level. When I hit stop, I still have the white noise and it is proportional to the volume level on the iphone.
This does not happen when the circuit is powered with a 9 v battery. It is nice and clean and (mostly) noise free. Some of the noise is due to the unshielded jumpers I am using to connect things, but the noise is not there when the iphone is not plugged in (but the jumpers are left attached to the circuit).
What to do here?
Thanks in advance!!!
Administrator
Joined 2007
Why do you need a transformer on the input ?
It sounds to me like you are applying to much signal to the LM386. Why not replace the transformer with a 10K pot (or preset) as shown in the application notes. I would then AC couple the pot input to the ipod/phone with a 10uf cap. Finally add a low value resistor (say 33ohm) directly across the ipod output (so you need two for stereo) to simulate the headphone loading. This is needed because some Class D output stages rely on the phones as part of the output filter. If you don't ultimately want the 10K volume control then you can replace it with a suitable fixed divider having first got the amp working OK.
Here is your effective power supply.
In your mini-amp circuit headphone and line level can be considered equivalent, so no conversion is necessary.
I second Mooly's suggestion's.
