Amp newbie attempting project
Old 22nd December 2012, 09:15 AM   #21
ForeverSka is offline ForeverSka
Alright well I just went ahead and bought both 470uF and a 6800uF (what was on hand) cheapo electrolytic caps. Yes I have read these are terrible to put in the signal path but for testing they are equally terrible and adequate. I noticed very little difference between the two caps on this setup which proves to me its fine.
One unintended thing... it picks up the oldies station with a 3.5mm plugged in.
Old 22nd December 2012, 09:32 AM   #22
sofaspud is offline sofaspud  United States
sofaspud's Avatar
You don't like oldies?
The filter doesn't have to be that low. Try the handiest picofarad cap you have. Was anything connected to the other end of the plug? If not it'd be more likely to act as an antenna.
Remember also that if you decide on the bridged circuit the series output cap is a moot point.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 22nd December 2012, 09:41 AM   #23
Yea connected or not I got the radio station. A little bit of volume on the computer and it would mask it but the second it went quiet I could hear a quiet rendition of "Thriller". I'll grab a little pF cap tomorrow and give it a go.
The final build will be an auto grade 50W Toshiba chip amp. Just ironing out the theory before I order one of those. Burnt one chip so far so its a good thing.
Old 22nd December 2012, 08:16 PM   #24
pacificblue is offline pacificblue  Germany
Add the RF snubber to the output as per datasheet, i.e. 2,7 Ohm resistor in series with 100 nF capacitor from IC pin 8 to ground.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 27th December 2012, 08:42 AM   #25
So I tried an RF snubber tonight. It kinda just adds a TON of noise... I mean you cant hear the RF anymore because of the chainsaw noise but that's hardly the effect I was thinking. How sensitive is this circuit? With resistors on hand I can do 2.2 ohm and 2.8 ohm (pair of 5.6 in parallel) but neither sound anywhere near good. Me being near it makes it worse so somehow my snubber is causing more EMI interference?
Old 27th December 2012, 09:18 AM   #26
sofaspud's Avatar
Can you post a picture of your circuit?
Old 27th December 2012, 09:42 AM   #27
Messy breadboard but you might just get the idea.
Old 27th December 2012, 10:24 AM   #28
sofaspud's Avatar
You don't show any input leads. (edit: nevermind that, my navigation was off) Using shielded wire there, and cleaning up the other wiring, is my best suggestion. Long & loopy wires invite RFI.
You could also try the simplest configuration of output capacitor only, verify it, and add to it while testing at each step. That should automatically localize noise and other effects on the circuit.
Old 27th December 2012, 06:24 PM   #29
Sounds like you shorted something. Are you sure that electrolytic has 0,1 F aka 100 nF? It should not have 100 F. The usual choice in this place is a ceramic or a film cap.
Old 20th January 2013, 07:57 AM   #30
Well at any rate this little chip is a fun science project but it is only 2.5W and even the best of speakers powered at 2.5W will barely overpower a noisy late 60s VW engine. lol
So lets discuss the TDA1557Q. Mouser claims NXP has discontinued this chip with no replacement so is it common to buy them from ebay sellers?
Then pin 12:
I think I've seen this discussed somewhere but hardly remember if an answer was ever offered up. "the harmonic distortion at low frequencies can be decreased by connecting two diodes to ground at pin 12." Can anyone expound on this? I'm imagining going to my local electronics store, picking a couple of their cheapest garden variety diodes off the shelf and hooking them to pin 12 in the direction of ground. Am I close?
Just making sure:
This chip has "speaker protection" so that means I don't need a speaker coupling cap, right?
Amp newbie attempting projectHide this!Advertise here!
Newbie amp project power supply noise rory1327 Solid State 7 29th December 2011 06:33 PM
Concrete Sandwich - Cheap & Cheerful Speaker Project (detailed, newbie friendly) jabney Full Range 2 11th October 2011 03:37 AM
Attempting a Chip Amp Build - Need a PCB! deadparrot Chip Amps 7 2nd July 2009 03:14 PM
Newbie trouble- First Amp Project TDA1517 dj_oatmeal Chip Amps 19 1st October 2008 11:56 PM
is this amp good for newbie project?? behnkem Solid State 5 13th March 2003 02:42 AM
