Need help designing crossover
Old 27th November 2003, 02:43 PM   #21
soundNERD is offline soundNERD  United States
Well, now I am waiting for the chips to get here. But until then, does the 837 and the 324 have the same pinouts and run off of a single supply, so I could use the 324 until the 837 arrives?
Thanks, Mike
Old 28th November 2003, 12:21 AM   #22
theChris is offline theChris
i'm betting yes. check www.national.com lm324 and lm837
if only it could be used for good, not evil...
Old 28th November 2003, 12:20 PM   #23
Looks like this is a split supply chip. I don't see a ground pin, though. It does have a VEE and VCC connections and says the max voltage is +-18V. If it is split, where is the gnd connection?
Old 29th November 2003, 04:42 AM   #24
that's the beauty of opamps, there is no ground pin.
basically ground is just a "referance". an opamp tries to do one thing: make the input terminal become equal in voltage by use of a feedback path.
as you can see, ground isn't mentioned, and doens't need to be attached to the chip. notice that all opamp circuits will have resistors attached to ground and to an input. this is a way of referanceing the signal to ground. so long as the output stays between +18V and -18V it is fine, and you could build the circuit so Vcc/2 was concidered ground.
Old 29th November 2003, 11:19 AM   #25
So I could just run it off of a single supply bv connecting + to VCC and gnd to VEE? And power it off of something like a 7805 (if that has enough voltage)? I do have some 7905 also, if it does need split.
Old 1st December 2003, 01:39 AM   #26
well, if you run from single supply you need to add a DC offset to the input signal, then remove it from the output signal.
basically, the opamp will try to output a signal that would make both input terminals be at equal voltage. now for an AC input, that means there are times when the opamp needs to put out a negative voltage, and times when it needs a positive voltage. if you run from a single supply, the opamp will not be able to put out negative voltages, as the power supply will not allow it. so if you add a little bit of DC to the AC signal, you will get a signal that you can work with, but also you will need to remove the DC offset. this means capacitors in the signal path. most audiophiles attempt to minimize the number of capacitors and especially the number that could most affect the signal.
i would use a split supply if possible. if you must do single supply: http://instruct1.cit.cornell.edu/cou...ngleSupply.pdf
Old 1st December 2003, 02:04 AM   #27
Thanks. The only reason I asked was because I know the LM324 is a single supply chip, and the 837 is a split supply. I didn't think it was possible to interchange them.
I can wait a couple of days for the samples to arrive.
Old 7th December 2003, 02:08 AM   #28
OK, I finally got the chips yesterday. Now, what would be a good circuit to use? Should I use the lowpass crossover in winisd pro? Or something else? Also, what order does it need to be?
Need help designing crossoverHide this!Advertise here!
Please help with the designing of a passive crossover network! Big_Bill Multi-Way 74 17th July 2009 04:53 AM
Designing a crossover oldbar Multi-Way 2 2nd February 2009 11:48 PM
Help for Crossover Designing for 3 way speaker CH2 Multi-Way 16 9th April 2004 04:01 PM
designing crossover fr Thiel and Eton... woofes Multi-Way 16 20th February 2004 03:58 AM
noob needs help designing crossover helpmeplease Multi-Way 3 21st December 2003 11:22 PM
Copyright ©1999-2017 diyAudio
