Velleman K4003 / TDA2616 - turn on/off pops - diyAudio
Old 29th October 2012, 03:05 AM   #1
IG81 is offline IG81  Canada
IG81's Avatar
Default Velleman K4003 / TDA2616 - turn on/off pops
I just assembled a K4003, based around the TDA2616 chip. Despite what is stated on the TDA2616 datasheet, I'm getting loud clicks and pops, at turn off mostly. I'm feeding the circuit with a Hammond 166L25, for a final DC supply of 19V. I measure DC offsets of ~30-40mV for each channel. What could be the problem here? The K4003 is the exact application circuit from the datasheet, I don't get it.
Other than that, I'm getting a clean output waveform up to 9.2V, for ~10.5W into 8ohm and it seems to sound fairly good.
IG
Old 29th October 2012, 06:08 PM   #2
cervelorider's Avatar
What kind of power switch are you using? I had the same trouble until I went with a heavy duty spst switch from parts express. Swap out switches and see if it helps.
Old 29th October 2012, 06:22 PM   #3
IG81's Avatar
I'm using a pretty simple rocker switch, made for AC 120V. I've used these a few times in other projects with no problem. I can try a swap. So would this be switch bounce? Thanks for the input!
IG
Old 29th October 2012, 06:24 PM   #4
balerit is offline balerit  South Africa
balerit's Avatar
If the chip is anything like the TDA 1558Q or similar chips you need a circuit add on to hold the mute pin low while the amp is powering up.
Mac
Old 29th October 2012, 06:29 PM   #5
IG81's Avatar
Mac
I might have to look into this if all else fails perhaps, I have not given the mute function any look so far.
IG
Old 29th October 2012, 07:03 PM   #6
balerit's Avatar
Have a look at the TDA 8560 datasheet page 11, for a similar circuit for the mute, though mine is simpler consisting of a cap and 2 resistors and a switch.
Mac
Old 29th October 2012, 07:54 PM   #7
IG81's Avatar
Mac
Interesting. The TDA2616 would want the opposite: to have some current (300A into ~9K input Z) go into the mute pin at startup, then slowly ramp it down for normal function. If changing the switch or de-bouncing it does not work, I wonder if I can make something with a Zener, resistor and capacitor towards this end. But I think the mute function only takes out the input section, so any transient generated by the switch might still make it to the outputs.
IG
Old 29th October 2012, 11:08 PM   #8
IG81's Avatar
A little blue X-type capacitor, 47nF, accross the switch did the trick, I only get very faint clicks now, with my ear to the tweeter. It's better than swapping the switch at this point since the hole is made.
IG
Old 30th October 2012, 03:32 AM   #9
IG81's Avatar
Here is a shot of this little amp, driving a Philips 9710 (rather appropriate) in a Karlson:
IG
Old 30th October 2012, 12:52 PM   #10
Gorgeous! I bet that combo sounds wonderful.
Velleman K4003 battery powered? c0reyl Chip Amps 8 18th April 2012 07:14 AM
Velleman K4003 power supply Gnitrops Chip Amps 15 1st March 2011 12:09 AM
velleman 2x 30W k4003 suitable? matthughes64 Chip Amps 4 8th August 2009 10:55 PM
The Velleman K4003 DD_Davo Chip Amps 0 13th December 2004 07:55 PM
Velleman K4003 using TDA1521, worthwhile upgrades? NewVintageNut Chip Amps 4 25th May 2004 07:30 PM
Copyright 1999-2017 diyAudio
