| Chip Amps Amplifiers based on integrated circuits |
I am just putting here this article:
Gain-X2 - LME49811 15-150Watt Gainclone amplifier ... it is kind of follow-up on this: Gain-X - LM1875 2*20Watt Gainclone amplifier I am right to think that this is extremely useful? |
#2 |
Well, it isn't bad as such but the PSU design for the LM1875-amp is completely off! Is it your site?
/U. |
#3 |
Gainclone is a specific topology around an integrated Power IC, or chipamp.
Your X2 has no resemblance to a chipamp. |
#4 | |
That is actually my site... Chip Amp Photo Gallery And what do you mean by competely off? Of course the regulating is not necessarily necessary... ;-) But in that particular case the 24v transformer would have killed the opamps in no time... That psu is also a compromise between power and size... And how much power does a 15W gainclone actually require from the psu??? Not 100W for sure - if it is regulated. Step 1: Understand the voltage limits of the opamp. Step 2: Make a PSU that does not brake those limits. |
#5 |
There are no opamps listed in either X or X2 amps.
#6 |
Could someone please define an operational amplifier for me.
Must it be implemented with valves to make one? As I understand, ideal opamp has:
If none fulfills the criteria, let's just call them all differential amplifiers then... Also all suggestions wellcome about my site. It is still under developement but I can see google has already googled it... I was going to 'release' it a bit later, but since it is now here, we might as well do it - now. |
| Any notice?? | tadiam1 | Solid State | 0 | 26th May 2010 10:40 PM |
| Ever notice those scratches on some plates?? | impsick | Tubes / Valves | 13 | 2nd March 2010 11:08 PM |
| any notice of this? | tadiam | Solid State | 0 | 1st December 2008 10:36 AM |
| ALEPH4 - URGENT NOTICE !!!!! | mefinnis | Pass Labs | 20 | 4th April 2001 10:02 PM |
