LME49810  1200RMS into 8 ohms amp possibility?
Old 26th October 2012, 07:05 PM   #1
rhythmsandy is offline rhythmsandy
Default LME49810 1200RMS into 8 ohms amp possibility?
Is it possible to build a 1200RMS into 8 ohms power amp with lme49810? what are the things to be done to the existing sample schematic from National? one of my friend wanted it for PA purpose but he wanted good class AB..
Old 26th October 2012, 07:22 PM   #2
peranders is online now peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I will give you some home work:
How many volts can you feed LM49810 with?
How many volts do you need for 1200 W into 8 ohm?
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 8 pcb's in interest so far.
Old 27th October 2012, 07:03 AM   #3
200v max for the lme49810
if the output voltage is 100 then we need 12 amps to get 1200watts..
considering v=IR so for voltage of 100 i= 100/8 = 12.5amps..
P=IV makes 12.5 x 100 = 1250watts
Old 27th October 2012, 07:28 AM   #4
peranders's Avatar
Almost right. 100 V peak is 71 V rms = (71*71)/8 = 625 W!
Notice that you should have maybe ±70-80 V max as supply voltage. The difference between 1200 and 625 watts is only 3 dB, mind that.
Have you checked that prices for new or used PA amps? They are not particularly expensive.
Old 27th October 2012, 11:09 AM   #5
so how many output transistors is required to get that much of power?
can I have more max supply voltage like 100 or more?
i am thinking of using this one or build everything from scratch...
Connexelectronic
if im using two of this modules then can I use them at 2 ohms?
Old 27th October 2012, 11:12 AM   #6
jaycee is offline jaycee  United Kingdom
If you really want 1200W RMS, you do not want class AB. At the very least you want Class G. Really you want Class D.
You won't be able to build anything as cheap as you can buy it, unless you're recycling parts.
edit: No, those modules will not work on 2 ohms, especially if you were driving them bridged. Either protection circuitry would activate, or you would burn them out as each one would see a 1 ohm reactive load. There are not many amps that will drive such low loads.
Old 27th October 2012, 11:31 AM   #7
peranders's Avatar
Maybe you should consider 2500 watts module?
http://www.hypex.nl/docs/UcD2kOEM_datasheet.pdf
Old 27th October 2012, 01:15 PM   #8
Typical of the many questions asked by R.
He has not got a clue and despite many Members coming in with assistance, R appears to have learned nothing.
regards Andrew T.
Old 27th October 2012, 02:01 PM   #9
peranders's Avatar
Connexelectronic
I work with electronics since decades back. I think that it requires high competence to design a good 1200 W 8 ohm amp. This is nothing I would do with my left hand exactly.
My advice is to look for a couple of used PA amps.
LME49810  1200RMS into 8 ohms amp possibility?Hide this!Advertise here!
15 ohms (12 on ohmmeter) with 24 ohms resistor in parallel to bring to 8 ohms McIntosh Man Multi-Way 29 11th June 2010 05:36 PM
my lme49810 AMP evangelion1999 Chip Amps 20 25th April 2008 03:51 PM
ISOBARIC 16 ohms load powered by 8 ohms Amp eddi0 Subwoofers 24 21st October 2006 03:29 PM
Copyright ©1999-2017 diyAudio
