| Chip Amps Amplifiers based on integrated circuits |
is it possible to add an balanced input to a classical TDA7294 design? I´m using boards from xy Audio, ver 1.1. I thougt that i´ve to add only a Resistor to the inv. Input. Maybe some of you can help. Thanx in advance, Andreas |
#2 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Yes, it is possible. In the circuit attached, remove the ground side of R3 from ground, and put there the inverted input, but a balance in the circuit must be performed for properly job, put a 330nF (or other value in this line also as in the NI input, and the same 680R in series to the input), so maintain the input balance between line signals.
As this changes varies the amplification factor, perhaps oscillations can get, in such a case, re-calculate for more closed loop gain. Good luck!
LW1DSE |
#3 |
What happens if nothing plugged into the input?
I think inverting input needs a resistor to ground. 22K? |
#4 | |
If no input, in such case, the amp is balanced, and no output will be.
LW1DSE |
#5 |
You are right. Thx
#7 |
I am in France.
#9 |
Thanx Oswaldo,
will try it this weekend. And report. Andreas |
| balanced input for any amplifier | atmasphere | Tubes / Valves | 11 | 2nd October 2011 12:27 AM |
| PP to balanced input | wicked1 | Tubes / Valves | 7 | 25th February 2009 10:21 PM |
| TDA7294/7293 with reg input stage supply | ashok | Chip Amps | 2 | 15th March 2008 07:55 AM |
| Aleph 3 balanced input | Odysei | Pass Labs | 10 | 2nd June 2005 03:02 PM |
| [P68] Balanced input??? | Tazzy | Solid State | 9 | 8th February 2003 12:52 PM |
