Hi, does anybody use this PCB for LM3886. I'm going to build 2 parallel/pcb. PCB it self for stereo and thickness of pcb 2.6mm.
Just wonder if I can use same componen value as it's printed. And input line are + and - instead L and R. The + and - goes to same pin number, so I conclude it is not bridge.
The black paint is very perfect to hide some copper track even scanner can't "see" it . I draw the scheme and use multimeter to trace connection of some point and get this:
(Sorry the R18K and C 1uf is connected to pin no 8 not to output)
I build one channel w/ 30 volt+/-DC and result is good, eventhough I do not put the C = 1 uf.
biased R=4.7k what does that refer to?I have qustion about feedback R=100k, and biased R=4.7k . I saw other scheme ussualy feedback R=20K.
Link to a schematic and use the schematic component labeling to make clear what you are talking about.
Andrew T,
Sorry . Actually I'm refer to the 4.7K in my drawing scheme.
Also I wonder is the elco =1uf is really needed ?
Upload again the scheme :
that schematic is visible for me
It's slightly unusual with such high input impedance and feedback resistor. I can't think of any good reason to do that rather than use the more usual 22K. Still, if it works and sounds good, it's OK
The input coupling capacitor, it depends on your source. If it has a low DC offset to start with, you can get away with it. Personally I would also like to have an input lowpass filter for RF rejection.
He has uploaded it again, here is the link http://i885.photobucket.com/albums/ac60/yd1cvj/IMG02073-20121025-1718.jpg
No idea why doesn't it work for you, AndrewT.
Regards, Vic.
Regards, Vic.
To balance the two inputs, the FB resistor (at -in) will usually be equal to the other resistor (at +in). The resistor at +in is connected to ground. The higher the resistance, the better the noise floor, as can be seen in simulators.
Beside lifting the input impedance, it is often mentioned in "Design Example" of a chip datasheet to use such a high resistance (usually mentioned as 100k) to lower output offset.
I have tested many resistance and the offset differences are not big. Even the lowest offset was not the best sound to my ears.
But with FB resistance as high as 100k you can get away with 4u7 MKP in the FB path. May be it is audible if compared with low quality electrolytic? (mine was BG, so no worse)
- Chip Amps
- LM3886 unussual pcb
