Can't get TDA7266 to unmute
Old 17th October 2012, 05:41 PM   #1
fretless123 is offline fretless123
Default Can't get TDA7266 to unmute
Hello,
i am trying to build myself an amp using the TDA7266SA chip. I'v made the PCB based on the datasheet's example schematic, however it does not work. The problem is that pins 5 and 6 (mute and st-by) never get the 6 volts from the voltage divider like they should, it is barely 0.6 volts. My supply voltage is at 12 volts. Below i have linked the PCB i made and the schematic from the datasheet.
Old 18th October 2012, 08:36 AM   #2
madtecchy is offline madtecchy  England
Your board layout is wrong. Mute pin 6 is not connected. Pin 7 is conected directly to pin 8 wich is power ground. You have also connected PW gnd and S gnd together at the chip. this is not a good idea as the high current pw gnd will contaminate signal gnd. ideally you need a thin pcb trace for s gnd going back to the ground side of your res capacitor ..
Best Regards Mark
Can't get TDA7266 to unmuteHide this!Advertise here!
TDA7266 Havoxx Chip Amps 8 11th August 2011 12:27 AM
TDA7266 suggestions jaste Chip Amps 2 3rd September 2010 01:49 AM
Buffer for TDA7266? jaste Chip Amps 7 2nd January 2009 06:33 PM
Copyright ©1999-2017 diyAudio
