Did I get the right Transformer?
Old 11th October 2012, 03:29 PM   #1
charliemopps is offline charliemopps
Default Did I get the right Transformer?
I got this kit:
1 LM3886TF amplifier AMP+RECTIFIER FILTER BOARD DIY KIT | eBay
and ordered this transformer for it:
http://www.antekinc.com/details.php?p=688
I just want to make sure I got the correct transformer. I know it's over powered, but that's just because I want to add a sub amp later on.
Any help would be great, thanks! (yea, yea, I should have asked before I ordered, but I thought I'd picked correctly and now I'm having doubts)
Old 11th October 2012, 03:40 PM   #2
Mooly's Avatar
Both links seem to bring the same thing up. Amp but no tranny that I can see. What are the specs of the tranny ?
Old 11th October 2012, 03:42 PM   #3
That was weird... but I fixed it. Try the link now.
Old 11th October 2012, 05:21 PM   #4
diyAudio Member RIP
Hi, dual 24VAC 300VA will be fine, rgds, sreten.
Old 11th October 2012, 06:16 PM   #5
Mooly's Avatar
Agreed...
Old 11th October 2012, 07:27 PM   #6
How much more VA/Watts can I run off that transformer without a problem? I want to add a sub later on. Could I get away with another 60 to 120 watts? I'm in the US with 120V 60hz, so according to their spec it should be rated at 360VA right? And what I've got now is 120watts... so 240 total on a 360 transformer?
Thanks for the help!
Old 11th October 2012, 07:49 PM   #7
Mooly's Avatar
In practice (meaning normal programme material) I think it will be fine.
Designing and specifying amps for continuous max rated output is a whole different ball game (and most commercial stuff isn't specified to be used like that either).
Old 12th October 2012, 01:58 PM   #8
a 300VA transformer will give good to adequate per4formance when powering amplifier totally from 150W to 300W.
eg,
5off 60W amplifiers could work very well from a single 300VA transformer, if you choose the correct voltage and (much more difficult) get the grounding correct.
regards Andrew T.
Sent from my desktop computer using a keyboard
Did I get the right Transformer?Hide this!Advertise here!
Newbie Question - Power Transformer vs Isolation Transformer SparkyPete Tubes / Valves 10 2nd November 2012 06:13 PM
Where you buy iron transformer core for DIY audio transformer tarsik Tubes / Valves 10 27th December 2011 08:15 PM
Dynaco 440 Transformer Cathode/Screen Taps 6P1P 6AQ5 UL transformer TheGimp Tubes / Valves 14 30th October 2011 12:20 AM
TV Fly-Back Transformer as and Audio Transformer Anyone :) AB5NI Everything Else 7 10th June 2011 11:22 PM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Copyright ©1999-2017 diyAudio
