Protection Relay
Protection Relay
Old 1st October 2012, 07:01 PM   #1
TP143 is offline TP143  United States
Default Protection Relay
I am looking to add a speaker protection relay to my LM4780 parallel kit. I have found many available on ebay but few elsewhere on the web. Does anyone have a recommendation?
Old 1st October 2012, 07:30 PM   #2
R.I.P.
One of the advantages of chip amps is the comprehensive protection,
so I can't really see used properly why a relay would ever be needed.
Proper use of the chips mute function fully emulates relay operation.
rgds, sreten.
Old 2nd October 2012, 01:50 AM   #3
Minion is offline Minion  Canada
I have had speaker frying from LM3886 a couple of times , once when I put the wrong gain set resistor so it was configured as unity gain and oscilated like crazy and caused by speaker to smoke a bit , It also happened once when i miswired the PSU to the amp so there was no -v which caused a huge DC offset which caused my speaker to heat up a bit ......
When it is configured correctly there is little chance it will fry yer speaker ......
Old 4th October 2012, 12:04 PM   #4
frank1 is offline frank1  United Kingdom
Because the protection doesn't work when these things fail.
They are more than capable of destroying a loudspeaker, just like any other amp.
Frank
Old 4th October 2012, 06:11 PM   #5
Does anyone have any experience with the cheap ebay relays? I have read that a relay can negatively influence the amps sound but I wasn't sure if this was limited to certain designs.
Old 4th October 2012, 06:56 PM   #6
Mooly's Avatar
Protection Relay
No experience of Ebay but relays can give problems. A subtle problem is distorted sound at low volume that mysteriously corrects itself when the amp is turned up. Cause... contact degradation, and the higher current at loud volume then finds a path through the contamination and all OK again... until the next time. Having had this happen to me I went down the solid state route. I don't think I'd go back to mechanical now.
Very long thread on this that finally gets round to SS relays, you'd have to read it all,
Output Relays
Protection RelayHide this!Advertise here!
Rewiring Protection Relay somejohndoe Solid State 5 22nd October 2011 03:17 PM
SOA Protection by Relay. mikeks Solid State 48 27th August 2006 08:04 PM
Speaker protection relay PH104 Solid State 4 20th February 2002 07:46 AM
