Old 28th October 2003, 09:37 AM   #1
Alvin is offline Alvin  Hong Kong
Default Balanced Gainclone circuit
Hi! May I know about more about the "true" balanced gainclone circuit?
Where can I get the circuit?
Also, will it be better sound instead?
Thanks very much!
Old 28th October 2003, 10:07 AM   #2
A non-inverted and an inverted gainclone...
Old 28th October 2003, 11:29 AM   #3
runebivrin's Avatar
Send a message via MSN to runebivrin
Oh, no!
That's a BridgeClone. A balanced clone is made up from two identical circuits with the loudspeaker connected between the outputs. The inputs are driven by a balanced output from a preamp.
Rune
Do wizards use spell checkers?
Old 28th October 2003, 11:59 AM   #4
Faber is offline Faber  Italy
Send a message via ICQ to Faber Send a message via MSN to Faber
I'm working on it.
It will be formed by a couple of 3 paralleled devices in non-inverting mode.
I'm using a +-24V at supply rails.
It will be drived by a Pass' Balanced Line Stage at aprox 60V supply voltage.
Actually it's not finished so I can't tell you if it's better or not than the BridgeClone
I will use a 25dB feedback formed by high precision resistors so to avoid the use of servos, but I will also drill some additional vias to put one if needed.
HTH. Bye, Fabrizio
Old 28th October 2003, 03:21 PM   #5
GregGC is offline GregGC  Canada
Isn't that what you meen?
Old 28th October 2003, 03:32 PM   #6
need to change R1 and R6 so their ratio is the same but the sum of their values is 10K (to match the input Z of the inverting side)
Old 28th October 2003, 03:56 PM   #7
Another one.
Old 28th October 2003, 04:21 PM   #8
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Mads K
Old 28th October 2003, 04:29 PM   #9
the input imedance of both paths is not equal. this prevents it from being balenced. it is differenetial input, thoguh. notcie the input impedacne of Vin- is R1 + R0, where the input impedacne of Vin+ is dependent on signal presented to Vin-.
if only it could be used for good, not evil...
Old 28th October 2003, 04:30 PM   #10
I’m not exactly sure of the advantages/disadvantages of the two circuits I posted. Second one has matched + and – input impedance’s but the input DC biasing is not that good. Can anyone enlighten me on the subject. I guess the 3 opamp version will be the best of both worlds.
Greg
Balanced gainclone sanity check xiphmont Chip Amps 56 6th June 2007 06:12 PM
New way to make a balanced gainclone? MtBiker Chip Amps 1 18th August 2005 04:11 AM
new balanced gainclone - the Studio Clone mr_squeegs Chip Amps 0 28th April 2005 10:44 AM
Balanced AC, GFCI, and my Gainclone Oborous Chip Amps 0 6th January 2005 06:50 AM
Balanced Gainclone ErikdeBest Chip Amps 2 16th April 2003 06:59 AM
Page generated in 0.09403 seconds (85.24% PHP - 14.76% MySQL) with 11 queries
