LM3886 DC offset and hum
Old 30th September 2012, 03:42 PM   #1
zimmer64 is offline zimmer64  Switzerland
zimmer64's Avatar
Default LM3886 DC offset and hum
Hi, I am new to the community and just built my first chipamp. A LM3886 stereo kit from chipamp.com. I followed all instruction and did not install the Ci cap. I use a 400va 2*24v toroid. I've put everything together on a piece of wood for testing purpose. I like the sound of the amp very much. It is detailed, kinda smooth, but powerful.
Here are my two questions.
Firstly, DC offset is 126mv on one channel and 97mv on the other. Do I need to worry? Have I made a mistake ?
Secondly, I hear a slight hum with my ear to the speaker. 10 inches away from the speaker it is inaudible. Again, do I need to worry? Have I made a mistake?
Any input is appreciated.
Regards from Switzerland.
Michael
Old 30th September 2012, 04:01 PM   #2
Arty is offline Arty
that DC offset is okay.
Do You use any volume controll device? like a potmeter?
(turning the volume down in Your computer's operating system -like windows - is not a good solution)
Old 30th September 2012, 04:24 PM   #3
zimmer64's Avatar
I use a little external box, a line driver, which has an Alps pot.: ABACUS electronics | Line Driver variable
The line driver has one input, to which an Airport express is attached at the moment. But the hum is the same with or without the line driver attached.
Old 30th September 2012, 04:54 PM   #4
WSJ is offline WSJ  United States
WSJ's Avatar
Remove the input wires and short the inputs with a 1/2" wire. This will eliminate external hum sources from the inputs, to determine the hum source. Used a hand drill to twist the speaker wires, the twisted wires limit noise going into the amp. from external sources. Twist the input, output and speaker wires at one twist per 1/2". Move the orange and gray transformer wires away form the amp.
Old 30th September 2012, 04:58 PM   #5
R.I.P.
You missed a capacitor.
That missing cap could be the cause of excessive output offset !
regards Andrew T.
Old 30th September 2012, 05:07 PM   #6
zimmer64's Avatar
I have not used the Ci capacitor, as the instructions said it is optional.
Old 30th September 2012, 06:57 PM   #7
necrofago is offline necrofago  Argentina
Try whit it.
Old 1st October 2012, 08:59 AM   #8
R.I.P.
Zimmer,
If I recommended that you cross the road without looking, it's only optional, would you accept that?
regards Andrew T.
Old 1st October 2012, 09:15 AM   #9
bcmbob is offline bcmbob  United States
This is a monoblock but the goal was to make all wires as short as possible. I didn't install Ci and both amps are dead silent. You might get better results with a metal chassis.
There is always the phantom of nearby noise generators with longer internal untwisted wiring. Check for light dimmers, halogen and neon lamps in the area. Try a diferent location or a different room. I get some noise when the amps are near a computer/monitor..
Also check section 1.7 in the user guide for optional placement of R3. You might consider swapping that placement
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 1st October 2012, 12:08 PM   #10
zimmer64's Avatar
Thanks a lot guys. As I said, this is my first amp. It seems that my AC wires are too close to the amp boards. My test setup also does not provide any shielding. bcmbob's design makes more sense. I guess I will also need to revisit some of the wires and twist them. I will also need to work on my soldering skills.... bcmbob's soldering looks a lot cleaner :-)
Michael
LM3886 DC offset and humHide this!Advertise here!
DC offset and gain on GC LM3886 Xerxes75 Chip Amps 19 9th October 2012 10:02 PM
LM3886 - DC offset problem luis.jimenez Chip Amps 22 10th April 2010 11:34 AM
LM3886 RC filter + DC offset questions. blackboy Chip Amps 2 27th April 2007 06:16 PM
Moved+changed preamp and now got hum and dc-offset whith chipampkits MiWi Chip Amps 1 4th August 2006 04:40 PM
Same old story LM3886 and DC offset officeboy Chip Amps 11 24th June 2004 02:51 AM
