Old 28th September 2012, 12:42 PM   #1
Default summing amplifier: does it really need output trafo?
one of my friend is not happy with the summing amplifier and he wanted me to check why is it not that good. Ive checked couple of products but they have a output trafo. I think thats why it had some distortion...
does it really required to have output trafo for summing amp?
the schematic is very simple File:Op-Amp Summing Amplifier.svg - Wikipedia, the free encyclopedia
I would like to do something like that in wikipedia in that case do we need to have the output transformer? can we eliminate that? Does it affect anything?
Old 28th September 2012, 05:08 PM   #2
djoffe is offline djoffe  United States
there is no need to pair a summing amp with an output transformer. The system would have to be just a bit unusual to have that requirement. For example, if you needed a balanced output with very good common mode properties, or very high ground loop isolation. Most common home hi-fi setups don't need that.
Akitika GT-101
Update My Dynaco
Summing two amplifier outputs with just a resistor perfknee Solid State 9 9th October 2011 04:51 AM
Got a big output trafo I want to use. lawbadman Tubes / Valves 27 29th October 2008 04:14 PM
How does a summing circuit work in terms of input/output impedances? Saurav Everything Else 3 16th May 2003 04:10 PM
Page generated in 0.40545 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
