Upgrade opamps in Asus Xonar Essence One DAC - advice needed? - Page 3 - diyAudio
Old 1st December 2012, 04:24 PM   #21
Boscoe is offline Boscoe  United Kingdom
Arghhh op amps... NE5532 is fine you can't hear the distortion in them it's in micro volts!
You can't hear the difference between two reasonable op amps, it's all marketing.
Audio projects and more: gswdh.co.uk
Old 1st December 2012, 05:18 PM   #22
danielwritesbac's Avatar
Originally Posted by Boscoe View Post
You can't hear the difference between two reasonable op amps. . .
Ideal support circuit design is different per each different model of op-amp, so it is probable that the majority of the differences heard by chip rolling is located in support circuit accommodation or mismatch. It could be better or worse, but of course there will be some difference. Those who explore long enough will find audibly favorable differences and then claim the replacement op-amp is much better for everything, but actually their favorable replacement was merely more suited to their application.
Therefore, after chip rolling with this result: "the sound is a lot better than the stock setup" means that this DAC application didn't include ideal support for the op-amp. Or, it could mean that those modern production NE5532's used in the DAC application are significantly different from the documented performance of Signetic/Philips NE5532's of the past, all bets are off with the new models, and in that case the chip rollers are simply populating their boards with non-fake op-amps.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 1st December 2012, 05:23 PM   #23
When was the last time you used formulas to determine external components with the numbers from the op amp datasheet. Proper implementation yes. If not its not compatible.
You cannot tell the difference your head makes it different.
Old 1st December 2012, 06:13 PM   #24
Do you expect new production clones/counterfeit to precision match twenty year old datasheet specs?
For reference:
New Asus Xonar's production is circa 2012.
The last authentic NE5532 was circa 1992.
Sockets are for removing counterfeit chips.
Issues Of Asus Xonar Essence Stx fotios Digital Line Level 3 13th March 2016 11:42 PM
Asus Xonar Essence ST overheating? barner PC Based 3 31st July 2012 12:27 PM
Gigawork DAC vs Asus xonar essence stx robump PC Based 13 8th April 2011 07:01 AM
New Asus Xonar Essence STX Drivers Brian Kingsbury PC Based 6 9th March 2011 09:52 AM
Copyright 1999-2017 diyAudio
