selecting a chip
selecting a chip
Old 24th September 2012, 04:16 PM   #21
Kitax is offline Kitax  Latvia
dont have a camera at the moment, but its still on bradboard anyways... :P ill probobly put in a pic of the schematic, with the pic of it inside a case, and with the finished boombox
should i get a 50w speaker just for the sake of this not happening
p.s. actually tested with different speakers... 20w speaker was a bit better, but couldent handle more than 3/10 volume
i was wondering about dual potentiometer... should i have gotten logaritmic one? couse i got a linear... there isnt much of a difference, but still...
Old 24th September 2012, 05:13 PM   #22
Arty is offline Arty
both will work.
and it should not get hot if you installed a heatsink, and there is no short circuit.
Old 24th September 2012, 05:26 PM   #23
well i heavent, how big should it be... (heatsink is a radiator, right? do i really need termopaste? its quite expensive... i think)
and what about speakers?
Old 24th September 2012, 06:17 PM   #24
Big. About a computer CPU cooler size , and you MUST use a thermal paste between the 2.
You could had killed the IC.
thermal paste can be bought in your local computer repair geek shop, for about 0.5 dolllar.
A used heatsink is quite likely to be there allso for cheap. Just find a way to securely mount it on the chip. (maybe ask a friend to drill 2 holes on the heatsink matching the chips factory made mounting holes, so you can use regular screws to secure it. just watch it to not overtihten things, you can damage the chip..)
A nother alternative is to ask for a dead pc powersupply. Those have nice heatsinks too, sould do the job. The bonus is that those have holes allready drilled on them, so you can use it straight out of the box, and most likely get it for free...
Old 24th September 2012, 06:22 PM   #25
thanks for idears...
selecting a chipHide this!Advertise here!
help selecting correct amp chip minoan_war Solid State 2 3rd January 2009 12:19 PM
Selecting an IT impedance Steven-H Tubes / Valves 6 23rd January 2008 11:54 PM
Need help selecting a driver for my 3 way 8675309 Multi-Way 43 14th August 2007 12:18 AM
Need help selecting DAC chip roee Digital Source 1 26th April 2004 05:55 PM
Selecting a project Hewie Multi-Way 1 24th July 2002 12:24 AM
