Old 29th September 2012, 04:26 PM   #21
ah, thatone.
forgot about it, 1557 does not have a diagnostic output.
Actualy You can go with any value as long as it is larger than 10K ohm.
//not even sure its needed if the diagnostic output is not used at all....
Old 30th September 2012, 08:38 AM   #22
Kitax is offline Kitax  Latvia
well it is needed... i thought that i didnt need it too... that's why i didnt get the 10k rezistor... :P
actually i wanted to change it only because the 4 rezistors didnt look too safe, to leave there... :P
Old 30th September 2012, 11:44 AM   #23
balerit is offline balerit  South Africa
balerit's Avatar
Originally Posted by balerit View Post
Well that's why I designed my amp with an input buffer, you can increase the gain if need be. If you have to add a preamp then use a TDA 7630 or TDA1524 and build a dedicated preamp. I use the TDA 7630 in my Camm EquiTone preamp and it is the best preamp that I have heard. I am currently building a new preamp to test the TDA1524 chip.
Arty I stand corrected on the 8560, the 1562 is an class H amplifier.
DIY Preamplifier - The Book Worm
Mac
Sorry guys, the preamp ic is TA7630p, got too many tda's in my head
Old 30th September 2012, 12:28 PM   #24
just stick to passive tone controlls.
chip has enough beef to handle it.
Maybe as a way of improving it a buffer could help.
Old 3rd October 2012, 02:47 PM   #25
i want to calculate, how fast my 7Ah battery is going to hold the tda8560q on various input voltages, how should i do that?
Old 3rd October 2012, 07:05 PM   #26
so.. say You drive 4 ohm speakers.
from a single 12v battery this chip will have something like 8v max output voltage.
we assume this swing.
so, 8/4 = 2A current.
this is stereo, so it will be closer to 4 A.
7/4 is 1,75 hours at full blast volume.
Does not sounds a lot.
but consider, that You will more than sure not run it at full blast.
I would estimate at least 3 hours of loud music.
//notice, one may argue that the amp has a certain % of efficiency, and a number of losses are to be included. But allso notice that speakers have impedance, my estimation is based on an ohmic load and constant current draw. //
Old 4th October 2012, 01:00 PM   #27
where did you get the 8v output?
Old 4th October 2012, 02:13 PM   #28
see datasheet.
test condition RL = 4 ohm
output power = 17w @10% THD.
P = U*I
P as power, U as voltage, and I as current.
I = U/R
where R is our load.
so P = Uˇ2/R
or sqrt(P*R) = U
witch is sqaure root of 68.
A tiny bit over 8 volts.
btw, it was only estimated.
Real life figures will differ.
It will be less output voltage since 10% THD sounds terrrible.
I would say that from a single 12v rated battery 8 volt output swing is on the edge.
Most likely You won't even utilise half of it.
It will be loud enough, given You use more or less efficient speakers.
Old 4th October 2012, 02:58 PM   #29
sofaspud's Avatar
It may sound odd, but a 7Ah SLA isn't likely to provide 7 amps for an hour, or 3.5 amps for two hours, or even 2.33 amps for three hours.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 4th October 2012, 06:22 PM   #30
well you could have just sait "the datasheet"couse i know how to do the math but thanks anyways ^_^
and sofaspud: that doesnt surprize me at all, but how do you explain it?
12V chip amp distortion maylar Chip Amps 8 11th September 2012 06:22 PM
FS: TDA1562Q 70W 12V chip amp ICs len_scanlan Swap Meet 1 12th June 2012 12:27 AM
chip amp 12V-18V srinath Chip Amps 4 10th March 2010 04:12 AM
Which chip for 12V subwoofer amp chr_madsen Chip Amps 11 1st January 2010 02:34 PM
how the best chip amp for 12V ? dito Chip Amps 5 29th October 2005 02:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
