| Chip Amps Amplifiers based on integrated circuits |
Typical specs I see for car receivers is 1% THD at rated power. I'm wondering what the major contributor is to that, and what they might be at higher load impedances. For instance, if the speaker outputs were used as a high level signal source (maybe 200 ohms load) with no speaker attached, would the THD still be 1% or would it be less? Anybody have an idea?
dave |
#2 |
Speaker outputs are designed to produce power, and so compromise on other things, so why would you choose to take a signal from there unless you wanted power?
Distortion comes from many sources, including the BJT exponential response. Negative feedback reduces this, but it can't work magic so when the circuit is nearing its limits the feedback correction begins to run out of steam. Using a higher impedance is likely to lead to a bit less distortion, but how much less depends on the circuit details. |
#3 |
well.. a higher load impedance will only reduce disorsion if the amplifier is not clipping allready.
Apart from that, larger load impedance will result in less powerdemand from the amplifier and will reduce distorsion, but allso available output power. But.. it will never be even close to stuff made for line level use. |
#4 | |
Most of the modern CD receivers say they have MOSFET speaker drivers. Anybody know the typical chip amp that's used today? Thanks
dave |
#5 |
Did it Himself
What the figure really means is that at 1% THD the rated power is...
If you keep the unit from clipping and connect a high impedance load the distortion will be much lower, quite acceptable. Note though still not as good as a proper line level feed. What you have to watch out for with car headunits, especially the modern ones with higher outputs, is that the outputs are bridged. So you cannot take one of the wires as ground or you will damage both the headunit and whatever you are plugging it in to.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 |
stick with line level.
if the unit has no rca out, then hack your way to the headunit chipamp and tap the signal there. |
#7 | |||
Bad idea. Tapping into a high impedance low level source is begging for noise problems.
dave |
#8 |
#9 | |
Did it Himself
The reason why output stages used as line stages are not quite up to a proper line stage is that of poorer behaviour around the crossover region. Correct.
| FS: TDA1562Q 70W 12V chip amp ICs | len_scanlan | Swap Meet | 1 | 12th June 2012 12:27 AM |
| chip amp 12V-18V | srinath | Chip Amps | 4 | 10th March 2010 04:12 AM |
| Which chip for 12V subwoofer amp | chr_madsen | Chip Amps | 11 | 1st January 2010 02:34 PM |
| chip amp with 12v DC AND 240v AC power supplies? | Vital AV | Chip Amps | 19 | 15th November 2009 10:39 PM |
| how the best chip amp for 12V ? | dito | Chip Amps | 5 | 29th October 2005 02:22 AM |
