opa549 pcb not working...
Old 9th September 2012, 11:16 PM   #1
rhythmsandy is offline rhythmsandy
Default opa549 pcb not working...
Gone everything right according to standard schematic...
When the input is given from the laptop I get 0 voltage at output of the pcb.
Ive tested the input signal voltage using a voltmeter im getting values ranging from 2mv to 25mv. When I measure at the output Im getting 0 volts. Guess what could be wrong? I think its the preamplifier. I think we need to give more input signal voltage like 1vrms is it so?
I had a yamaha amplifier which is a integrated amplifier and had CD RCA input and it worked fine with the same input from the laptop It had Sanken mosfets.
I think its the signal voltage what do u say guys.. I have checked the schematic 10 times its right no mistakes there even the polarity of bypass caps is fine..
what do you say....
Old 9th September 2012, 11:59 PM   #2
HIPCHECK is offline HIPCHECK  United States
HIPCHECK's Avatar
Please post your schematic, and if you can pics of top and bottom of pcb. Sometimes it can be really obvious to someone else.
Steve
If a inch of duct tape will fix it, 3 feet should fix it for life!!!!
Old 10th September 2012, 08:31 AM   #3
R.I.P.
Is this the same 549 that is in your other 549 Threads?
regards Andrew T.
Old 10th September 2012, 08:46 AM   #4
pinkmouse is online now pinkmouse  Europe
pinkmouse's Avatar
What have you done with pin 8?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 13th September 2012, 05:40 PM   #5
http://www.diyaudio.com/forums/attac...-ok-opa549.gif
I have shorted the pin 8 with pin 6
Old 17th September 2012, 07:27 PM   #6
here is the snapshot of the pcb that im using..
ImageShack® - Online Photo and Video Hosting
Old 17th September 2012, 07:28 PM   #7
please help me it seems that all the circuit is made accordingly but it doesnt work... no hint of sound coming from the speaker...
checked the power supply 14-0-14 after rectific im getting 19.75-0-19.75
I think I can try point to point and workout something out of this... but i doubt that the above schematic works properly or not..
Old 17th September 2012, 08:06 PM   #8
Bone is offline Bone  United Kingdom
What have you done with pin 7? Pins 10 & 11 should go to V+.
Old 18th September 2012, 02:40 AM   #9
5 and 7 connected to -V
10 and 11 connected to +V
8, 6 shorted
9 ignored ( left without any connection )
Old 18th September 2012, 02:42 AM   #10
today ill do point to point let me see how it works since its a simple circuit I believe it should work.
opa549 pcb not working...Hide this!Advertise here!
F/S Fully stuffed and working B1 pcb Marra Swap Meet 1 22nd February 2012 10:18 AM
FS: B1 stuffed/working PCB Bengali Swap Meet 1 17th June 2010 05:35 AM
100%working SMPS whit pcb needed sk_tuner Power Supplies 3 15th February 2007 11:44 AM
WTB Krell KSA Mk2- working or non working Jozua Swap Meet 0 20th March 2006 11:14 AM
