Got 8200pf Polystyrene caps 63v.  Where can I use them in audio circuits
Old 5th September 2012, 07:23 PM   #1
rhythmsandy is offline rhythmsandy
Default Got 8200pf Polystyrene caps 63v. Where can I use them in audio circuits
I got a 8200pf polystyrene cap which is said to be best dielectric for audio but since the value is small I was a bit confused where to use these? Decoupling? or parallel cap with tweeter cap?
Old 5th September 2012, 07:27 PM   #2
DF96 is offline DF96  England
Not an electrolytic. 8200pF might form part of an RIAA network, as polystyrene caps are often close tolerance.
Old 5th September 2012, 07:42 PM   #3
yeah sorry not electrolytic but dielectric....
Old 5th September 2012, 07:45 PM   #4
Humble Homemade Hifi
in the last he states about vishay 1837 cap which is not yet polystyrene but what if we use polystyrene in parallel with the tweeter cap. I believe it would sound good... i will try tomorrow and give the feedback over the forum... but if anybody tried at any part of the network please do let know it will be pretty useful...
Old 6th September 2012, 09:49 AM   #5
Ive added this cap in parallel with the tweeter cap and whoaaaa the tweeter opened alot in its highs.. It was strange to see that small value made a big difference but finally the inductance of the big cap is being bypassed by the small cap and since its polystyrene i believe it sings way too good..
the same song same volume the highs opened up way alot..
Old 6th September 2012, 06:20 PM   #6
After 5hrs of continuous use... I got the highs getting super smooth and yet very very detailed... I am probably buying 94 caps left with the dealer for life time... or use very few in reference systems..
Old 7th September 2012, 08:01 AM   #7
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
Clean the stock out - 8.2nF also works fine for C7 on the MyRef, and polystyrene film/foil is the highest quality film cap available. The only thing you have to be careful about is soldering - the film can get damaged easily by high temperatures conducted through the leads during soldering.
Old 7th September 2012, 04:16 PM   #8
Two days its been running Im in love with them like its said cant live without them. I will clean sweep the stock. There are other lower values few in thousands of pf and few in hundreds also ill clean everysingle value and cap.
you mean to say decoupling for the preamp? do you think its worth enough to decouple the pow amp aswell?
Im thinking to use another cap which is 10 times lower than this in parallel with the current configuration and another one ten times less than this. Hope its the holygrail for the tweeter.
As of now the tweeter is like dominating the mid sometimes my attention gets more towards the tweeter and its sooo soft and kind yet very very detailed...
Any tips to use these in amps will be very helpful.. Im thinking to use them as decoupling cap as well any suggestions. Ive seen your myref design seems nice...
Old 7th September 2012, 04:33 PM   #9
I will open one cap and see how its constructed and if possible get the polystyrene film roll and make some bigger values like .1uf or 1uf. I understand they will be large but if somebody is able to afford one or two cubic foot space for the tweeter crossover or a cubic foot in the amp for outstanding quality we can do that. Some say that the material is not available any more but I see lots of people are using them for other purposes. Why cant audio... Ill try but need some time before getting into building big caps. Since it has best chars its better to make a cap out of that..
Old 7th September 2012, 05:43 PM   #10
optimationman is offline optimationman  United States
Default NO styrenes
Yeah, I have some old NOS small value ones. Also have pulled some used ones from old equipment that are 23000pf to 69000pf values and 63vdc. Rather large as you indicated they would be. Haven't used them much. Tried them in the bypass mode, but didn't leave them in.
I have tried to eliminate capacitors from the signal path, and only have one in the power amps and have not needed to bypass anywhere else. Glad that you found them to be of such value!
Got 8200pf Polystyrene caps 63v.  Where can I use them in audio circuitsHide this!Advertise here!
Polystyrene Caps For Filters wrenchone Analog Line Level 46 5th May 2016 11:53 AM
Silver Mica caps VS Polystyrene caps KevinLee Parts 41 11th November 2015 03:38 PM
Polystyrene Caps maxseeley Swap Meet 0 31st May 2011 06:58 AM
Styrol/Polystyrene Caps Bigred Parts 2 6th September 2010 08:49 PM
ERO KP 63V 5.6nF Polypropylene vs RIFA 200V 5.56nF Polystyrene LosNir Parts 2 11th March 2010 10:32 PM
Copyright ©1999-2017 diyAudio
