Impedance matching using lm324
Old 4th September 2012, 06:01 PM   #1
scarebyte is offline scarebyte
Default Impedance matching using lm324
I have an intercommunicator, that have an speaker/mic. I want to connect it in parallel and using an comutator, to a mic and speaker. For impedance fix I'm using an op-amp(lm324) in buffer configuration. I get notorious distortion, so I'm using a 6.8kohm connected to ground and out, that is ok?. The mic have 500ohm rate impedance output. The connections in the figure are ok?, how can improve?
Thanks.
Regards.
Old 4th September 2012, 07:10 PM   #2
donpetru is offline donpetru  Romania
donpetru's Avatar
Is not quite correct, because the resistance of 6.8K will change output impedance.
Old 4th September 2012, 08:11 PM   #3
Ok, so what could be a good configuration?. And which opamp use if my supply voltage is 32Vdc?
Thanks.
Old 4th September 2012, 09:28 PM   #4
grommeteer is offline grommeteer  Germany
To be honest I do not quite understand what you are doing.
You cannot drive a speaker with the LM324 because it can sink and source too little current. You cannot amplify an AC signal with a single supply Opamp without a DC offset. The fact that the LM324 is a very poor audio amplifier will probably be your least problem. Why not make a more detailed/exact schematic? Then we can discuss in detail.
Impedance matching using lm324Hide this!Advertise here!
Impedance matching oleoleo2 PC Based 0 18th April 2011 07:05 AM
Impedance matching nogoodboyo Tubes / Valves 3 17th March 2006 11:55 PM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
impedance matching fragman56 Tubes / Valves 17 20th March 2003 02:38 PM
Impedance Matching bryce66 Solid State 6 9th November 2001 09:02 AM
