| Chip Amps Amplifiers based on integrated circuits |
Is anybody know good IC's for driving mosfets ,for example like TDA7250 except for mosfet transistor.
Thanks! |
#2 |
Electrons are yellow and more is better!
Linear had one LT1166 but according to reports it wasn't so good. I think it's still best to use discrete driver transistors.
Have you checked Jan's LYNX amp? http://www.audio-circuit.dk/ LYNX amp problems...Help
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
Thanks Peranders.
I wanted something cheap and simple for home theather use. I'll checkout lynx amp. |
#4 |
Well, I know i'm not the right one to say, but...
Isn't LM4651N a mosfet driver? |
#5 |
Yes, the 4651 is a mosfet driver, designed for the 4652
#6 | |
Only works with 4652, or can drive individual Power Mosfets? |
#7 | |
Account Disabled
I thought that's a PWM controller. On to TDA7250. I am not sure if the bias is current based or voltage based. But even if it is specifically designed for BJT output devices, you can still make it work with MOSFET devices. How? Well, you can use the 7250 to drive a pair of BJTs which in turn drive the MOSFETs in CF configuration. On the 7250, is it designed to drive just one pair of BJTs or it can handle darlingtons as well? |
#8 |
I don't know the exact details, but by reading the datasheet for the 51 and 52, it says that the 51 is a mosfet driver. I would assume that it would work for any mosfets, but as I haven't built any, I can't help you that much.
-Mike |
#9 |
Well, National send me 2 samples of each 4651 and 4652.
I'm goint to drive some Power Mosfets with the 4651 and post here the results. I hope that I still alive to tell Pedro Martins |
#10 |
Account Disabled
I just checked the datesheet. The 4651 is a pmw controller driving a mosfet H-bridge (4652).
So if you are looking for a class D subwoofer amp (its performance isn't too hot), you got the right devices. |
| Mosfet N-Channel Audio Driver IC .... wanted | qsa | Chip Amps | 1 | 9th November 2008 06:07 AM |
| Mosfet driver IC's | hairylee | Class D | 92 | 30th March 2008 04:22 AM |
| Mosfet driver options | Pozar | Class D | 10 | 22nd January 2008 03:02 AM |
| Page generated in 0.12562 seconds (67.54% PHP - 32.46% MySQL) with 10 queries |
