advice will i blow it up :/
Old 30th August 2012, 01:43 PM   #1
stenwo123 is offline stenwo123  United Kingdom
Default advice will i blow it up :/
Ok so my setup is cheap and but i think it sounds rather good
the thing is i have it setup in a strange way and want to know if it will blow up either my hifi or my power amp ok please look at the diagram and tell me if ime stupid or not lol
My whole reason for doing it this way was to seperate the low wattage speakers from the power amp whilst still being able to use them
Old 30th August 2012, 02:02 PM   #2
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Your picture resolution is only 180x124.
Old 30th August 2012, 03:15 PM   #3
hmmm so i see lol ille try another image hoster
Old 30th August 2012, 03:22 PM   #4
hmm so i see heres a better one i hope sorry about that Click the image to open in full size.
it would appera that every site is full of god damn adware i hate the net these days anyone got a suggestion for a good image hoster ?
Old 30th August 2012, 03:30 PM   #5
iko is offline iko  Canada
iko's Avatar
On the image shack site there's a button in the upper right corner, named Links to share this image. Click on it and attache the "direct link"
Old 30th August 2012, 03:34 PM   #6
ok ille try to explain the way i have it setup sorry about all the posts for some reason the edit button isnt working for me :/
ok so i have the following
techniks hd50 mini seperates 90w
2x 60 watt techniks speakers
skytekc 480 pro power amplifier
2x 400 watt soundlab disco/pa speakers
so i have it setup as such
from the speaker outputs on my techniks hifi the cables firstly go to my techniks speakers
from there a cable for the left and a cable for the right go into the inputs to my power amp
then my power amp is connected to my 400w speakers
i was sometimes use my hifi without the power amp turned on ie i only use the basic 60 watt speakers
will sending power allbeit not a lot to the power amp when it is not turned on do any damage to the power amp
and when i have the power amp on am i risking blowing anything up the diagram displays it better than i explain
Old 30th August 2012, 03:43 PM   #7
image shack wont let me use it now wtf lol anyhow i think ive got more than 1 double post waiting to be let through by the mods
Old 30th August 2012, 03:58 PM   #8
iko's Avatar
Since you have the image on your own computer, you should just upload it when you post via the Go Advanced button. Here you go.
Old 30th August 2012, 04:12 PM   #9
So you basically have the outputs of two different amps wired in parallel? Then yeah..... that's bad.
Old 30th August 2012, 04:27 PM   #10
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
No. He has the outputs of one amp feeding the inputs of another amp.
I would add voltage dividers between the outputs of one amp and the inputs of the other.
Frank
advice will i blow it up :/Hide this!Advertise here!
It will probably blow up blistard The Lounge 13 6th December 2011 09:35 PM
NAD fuses, slow blow or fast blow? AllCaster Solid State 3 25th October 2009 07:11 PM
Blow up once, Blow up twice and Blow up somemore S.C Chip Amps 14 6th March 2005 01:09 AM
Will This Blow Up? Trout Instruments and Amps 8 6th February 2005 01:52 PM
Will it blow up? dickerbeen Everything Else 1 17th April 2003 06:21 AM
