sound Quality of OPA549 when compared with LM3886
Old 21st September 2012, 09:17 PM   #21
Cannot be biased into ClassA.
It's an IC chipamp !
regards Andrew T.
Old 21st February 2013, 08:26 PM   #22
alexbio is offline alexbio  Russian Federation
Originally Posted by juma View Post
I used OPA549 as an audio amp too, in Nelson's Super Symmetry topology. That's the only AB class amp that I kept and still listen to occasionally - it regularly surpasses the expectations.
Here is the sch. (small error - 220p caps should be 5-10 times smaller)
Hi Juma!
1) Could you explain why feedback capacitor (220p) should be 5-10 times smaller? Will 200p cap attenuate signal at higher frequencies?
2) Question about the amp based on Walt Jung's paper on composite amplifiers
Could it possible to increase R1 to 3.32 kOhm. Firstly, I have a this value on hand in contradistinction to 3k. Secondly, is it OK to increase R1 so that LT1361 will amplify voltage, and OPA549 will amplify current?
Old 21st February 2013, 09:17 PM   #23
FoMoCo is offline FoMoCo  United States
What he said.
Well... Maybe a current source of several amperes tied from output to a rail. Then there's that pesky heat problem...
Account Deletion Requested: 1/26/2014
Old 23rd February 2013, 09:55 PM   #24
juma is online now juma  Germany
juma's Avatar
Originally Posted by alexbio View Post
Hi Juma!
1) ...Will 200p cap attenuate signal at higher frequencies?
2) ...Could it possible to increase R1 to 3.32 kOhm. Firstly, I have a this value on hand in contradistinction to 3k. Secondly, is it OK to increase R1 so that LT1361 will amplify voltage, and OPA549 will amplify current?
1) Yes
2) it's OK to make R1=3k3 and R2=10k so that in total gain LT1361 contributes with gain of about 6 and OPA549 with gain of 3. If you use OPA549 with unity gain (current only) the output power will be lower since LT1361 works with maximal supply voltage of +/-18V and OPA549 can go up to +/-30V.
Old 23rd February 2013, 10:11 PM   #25
jcx is offline jcx  United States
maybe not one - but 2 can:
...I explained some Class A push-pull op amp output bias concepts in my (jcx) posts:
AD8397-class A?
... higher power class A amps could be made similarly with "GainClone" power audio amp chips which are monolithic power op amps
simplified Class A push-pull output bias circuit:
Old 29th May 2017, 06:34 PM   #26
PMA is offline PMA  Europe
PMA's Avatar
Just happened, I measured OPA549 today. At 11W/4ohm. It is difficult to imagine any worse audio amplifier.
Old 2nd June 2017, 09:10 AM   #27
mt490 is offline mt490
Looks spot on to the claims of the data-sheet.
sound Quality of OPA549 when compared with LM3886Hide this!Advertise here!
TDA7293 versus LM3886 sound quality dildel Chip Amps 25 31st May 2013 08:16 PM
soundstream reference class A 6.0 compared to McIntosh MCC404 in sound quality russdeanlee Car Audio 0 5th February 2012 11:33 PM
soundstream sa244 compared to original reference line in terms of sound quality russdeanlee Car Audio 1 27th December 2011 11:12 PM
Trade: OPA549 for LM3886 or LM4780 bigmike216 Swap Meet 0 13th August 2005 04:34 AM
Sound quality: LM4780 vs LM3886 MWP Chip Amps 30 14th October 2004 12:22 AM
