2x bridged TA2022 180w x 2ch
Old 28th August 2012, 01:55 AM   #1
2ndwind is offline 2ndwind
Default 2x bridged TA2022 180w x 2ch
Ordered the board fully assemble from a seller on ebay. It recommends using a AC22v-0-AC22v output transformer with more than 350va. I have a 22v + 22v 160va toroid transformer. My question is will my 160va TT power this amp board? At least until I get bigger transformer of course. Would there be any resulting effect on the 160va transformer itself?
I assume the result will be the chip amps not producing as much power than if it had sufficient VA from the transformer, also I'd expect a 160va transformer to run hot in this application being fully taxed at 50% volume. Is that an accurate assumption?
Old 28th August 2012, 09:50 AM   #2
The amp will run just fine.
BTW,
you have no hope of getting 180+180W from that chip, even if you used a 500VA transformer
It's specified @ 90W into 4r0 with +-31Vdc and 60W into 8r0 from +-35Vdc
regards Andrew T.
Old 28th August 2012, 12:15 PM   #3
This is a two chip amp. One chip bridged per channel. 180w would maybe be reach at the maximum voltage of 36v, but I don't plan on pushing it that far. 22v should put it over 100w per chip-bridged and that will be plenty for now.
Thanks for the reply, I'm more confident the 160va transformer I have will work fine for now. I should at the least get me though testing.
Old 30th August 2012, 10:46 AM   #4
Atjan is offline Atjan  South Africa
I've got a Topping TP60 which uses the TA2022 chip. The unit uses 2 transformers and weighs about 5kg. I know this is pretty rough, but based on the typical weight of transformers, I'm guessing their VA rating is around 225VA. The manufacturer claims 50W/channel into 8 Ohms and 80W into 4 Ohm.
Topping TP60 Tripath TA2022 50WPC (80WPC 4 Ohm) Amplifier 310-326
2x bridged TA2022 180w x 2chHide this!Advertise here!
12V to 32V 180W SMPS WSJ Car Audio 15 27th June 2011 05:28 PM
FS: 2x UCD700HG+HxR, 2x UCD700 PS, transformers, accessories. TrNSZ Swap Meet 0 28th April 2011 02:10 AM
Less 35% Off Sale - nxV200 180w Modules The Saint Aussie Amplifiers 1 16th November 2010 01:44 AM
FS : RIFA PEH169 85, 350VDC, 2X 3300uF, 2X 220uF 00940 Swap Meet 0 11th March 2006 03:34 PM
180W folded cascode (just fooling around) PanzerLord Solid State 13 12th December 2005 12:13 AM
Copyright ©1999-2017 diyAudio
