LM4780 Questions
LM4780 Questions
Old 31st August 2012, 08:20 PM   #11
Marra is offline Marra  United Kingdom
LM4780 Questions
These are a nice switch for two inputs.
5646A9 - APEM - SWITCH, DPDT | Farnell United Kingdom
Old 1st September 2012, 08:52 PM   #12
Einric is offline Einric  United States
Einric's Avatar
Digikey also carries DP3T switches if you want another input.
Old 2nd September 2012, 04:30 PM   #13
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros LM4780 Questions
Originally Posted by TP143 View Post
The stock supply caps are 2@10uf but the recommended mod is 4@6800uf, not 6.8uf. I wanted to make that correction for future scanners of this thread.
you sure they said 10uF and not 10mF?
Old 2nd September 2012, 06:03 PM   #14
No 4 is offline No 4  United States
The audiosector kit come with 10uf (microfarad) capacitors.
Old 2nd September 2012, 08:10 PM   #15
lanchile is offline lanchile  United States
lanchile's Avatar
yes! they come with 10uf for power supply (joke).
I am very happy with my TKD in my amp too. it is very smooth and it is a big step up from Alps for sure
Old 2nd September 2012, 09:07 PM   #16
jackinnj is offline jackinnj  United States
jackinnj's Avatar
LM4780 Questions
If you are going to parallel the LM4780 it's a good idea to match each amplifier's Rf and Rg to 0.1%
Vee and Vcc should be bypassed with 10uF electrolytic AND 100nF ceramic.
Old 3rd September 2012, 09:59 AM   #17
R.I.P.
Cs in the datasheet are mandatory.
yes, once you have Cs fitted then you can experiment with values, but they must be fitted first.
regards Andrew T.
Old 3rd September 2012, 12:36 PM   #18
jackinnj's Avatar
LM4780 Questions
And while you're at it -- if you're going to switch the mute, then a little electrolytic on the mute pin is helpful -- but make sure to note the polarity.
Old 3rd September 2012, 07:04 PM   #19
KaffiMann is offline KaffiMann  Norway
KaffiMann's Avatar
I actually just got some SMPS from connexelectronic for my LM4780's (for bass) and LM3875's (for alpair 12), sounds very nice, ended up being cheaper than the good'ol power transformers, but I have heaps of them anyways. Put them in a MDF box I glued together for the purpose, everything is connected to the heat sink. Planning on adding an active xo and use the aux power from the SMPS for it. Just have to use my minidsp to figure out what I need first. And build the boxes for the Alpairs...
Old 11th September 2012, 08:27 AM   #20
sangram is offline sangram  India
The PD kit comes with 1510uF total capacitance per rail per amplifier. 1500uF on the ap board and 10uf on the PSU board. PSU board takes 10,000uF snap-in capacitors pretty easily. I have 4700uF+1500uF+10uF fitted on 4 amplifier boards (2 PD kits) in bridge-paralleled configuration and there is enough bass to pull down a wall, even with the tiny little Zaph L18 speakers.
Note the earlier caution about running multiple PS units off the same transformer. In reality it does work, But you have to absolutely match diode polarities. It caused me a lot of confusion the first time around. Each pad on the PSU board must be routed to exactly the same winding output terminal else the back-to-back diodes effectively short-circuit the winding.
LM4780 QuestionsHide this!Advertise here!
tech-diy LM4780 board questions Burnedfingers Chip Amps 7 22nd September 2017 04:12 PM
LM4780 source questions bushroot Chip Amps 9 16th March 2008 05:38 AM
Sub' Amp - LM4780 questions! raromachine Chip Amps 23 3rd March 2007 03:20 AM
bridging 2x paralleled LM4780 per channel - few questions bikehorn Chip Amps 6 28th April 2006 06:13 PM
Several Questions about the LM4780 GainClones geewhizbang Chip Amps 14 15th June 2004 08:18 PM
