LM3886 problems LM3886 problems - diyAudio
LM3886 problems
LM3886 problems
Old 18th August 2012, 10:32 PM   #1
Navin_R_Johnson is offline Navin_R_Johnson  United States
Default LM3886 problems
I bought some of the BrianGT boards and stuffed 2 mono blocks. At first listen the highs were piercing and the lower end was bloated and overwhelming, very bad! After a bit of thought I figured I might have an impedance mismatch because I'm not using a volume pot so I put a 25k R on the input to ground.
Results in the high/mid frequencies were better but still not good, can't seem to get much "imaging" from them. An oddity, they drive my old Mirage 280i's (test speakers) with sloppy, bloated bass. When driving my Ariel's there are no lower frequencies to speak of, no measurements but I'm guessing the Ariel's are rolling off at 50-60Hz.
It's has been near 20 years since I've used my electronics training but, this problem is still making me feel stupid! I'm guessing I'm overlooking something obvious.
Quick specs:
BrianGT boards stuffed to specs.
Triad 48VCT 100VA per channel.
Temporary test chassis with no signal input filtering.
Tried several source components, CD, TT(VSPS preamp) and an MP3 player
Any ideas what might be going on here or how to troubleshoot with minimal equipment?
Old 19th August 2012, 12:54 AM   #2
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
Where did you buy the chips? There are problems with fake chips being sold on flea-bay and such. Also, a schematic of what you built would be helpful.
Mike
Old 19th August 2012, 02:53 AM   #3
I hadn't considered the chips might be fake. I did buy through a US supplier but they are a discount/second hand type place.
Here's a link to the assembly manual for the amp. The schematic is on the 3rd page
http://chipamp.com/docs/lm3886-manual.pdf
Thanks for the reply,
Rick
Old 19th August 2012, 05:14 AM   #4
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
What kind of amp were you previously using with your speakers?
Brian
Old 19th August 2012, 06:52 AM   #5
To put things in perspective, my $30 off the shelf Labtec PC amp (using LM1875's) sounds much better.
Rick
Old 19th August 2012, 11:28 AM   #6
Originally Posted by Rnickl View Post
................. with no signal input filtering...............
That's your first mistake.
Fit both a Low Pass Filter and a High Pass Filter to turn your amplifier into an Audio Signal Amplifier.
Once these passive filters are in place, you can alter component values to change the turn over frequency/ies of these filters (independently) to hear the effects and you may be able to come to some conclusions that tell you something about your room/ears/speaker interactions.
Have you fitted all the stability component options?
A badly behaving amplifier can/will sound horrible !!!!!!!!!!!!!
The p3 schematic shows 6 stability components, Cs has 4 caps, Rz & Cz on the output. There is R//L missing on the output. Are Cs in the correct location? In the wrong location they can be effectively useless.
As noted earlier the High Pass Filter will also give you a DC blocking cap on the input. That cap must be in the correct location, after the volume pot.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th August 2012, 07:46 PM   #7
bcmbob is offline bcmbob  United States
LM3886 problems
Rnickl,
Please take a look at this thread. The RR is a little gem.
http://www.diyaudio.com/forums/chip-...ml#post2924833
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 19th August 2012, 09:07 PM   #8
Thanks for the input Andrew. Yes, all the stability components are in place but I did omit RL. Perhaps that is my problem here. How many watts does RL need to be? I'm assuming it needs to be fairly high power, is that correct?
"Fit both a Low Pass Filter and a High Pass Filter to turn your amplifier into an Audio Signal Amplifier."
I'm a bit rusty, OK way rusty, on this stuff. Can someone push me in the proper direction on how to calculate the values for this?
Thanks to you also Bob. I ran into that thread a few days ago and it might be something I play with down the road a bit. I need to get something that sounds reasonable first.
Rick
Old 20th August 2012, 09:19 AM   #9
the R of the R//L passes significant signal only when the L impedance approaches as high as the R value. That will not happen in the Audio passband. R should never heat up unless you test with high frequency signal, say around 300kHz to 1MHz.
I use a parallel pair of 10r 600mW for an effective 5r, 1.2W
Similarly the R of the R+C should only get hot on HF test signals. I use a quad set of 10r for an effective 10r, 2.4W
Finally I add a R+C at the speaker terminals. This R is just a pr of 10r for a total of 5r. The amp output sees all these R values at HF as a single 10r load, when the speaker cables are not fitted.
The input filter can be
Low Pass RC: 1.5us to 0.3us
High Pass RC: 10ms to 200ms
RC time constant = R value times C value, i.e 1ko times 47uF = 47ms
F-3dB turn over (roll-off) frequency = 1 / Pi / 2 / RC
regards Andrew T.
Old 20th August 2012, 11:54 PM   #10
Thanks much for the input Andrew. I didn't have proper values but I did fit a couple caps that seem to have put me on the proper path. I'll need to pick up some components for fine tuning.
Rick
LM3886 problemsHide this!Advertise here!
Problems with Chipamp (LM3886) BrianGT Puffin Chip Amps 46 25th June 2014 09:22 AM
LM3886 Chipamp problems... FenderBender11 Chip Amps 30 18th July 2012 03:09 AM
Chinese LM3886 Board having problems mattthegamer463 Chip Amps 20 13th November 2009 04:46 AM
LM3886 Problems ooops! Chip Amps 2 9th February 2009 08:09 AM
LM3886-problems joensd Solid State 5 24th June 2002 06:43 PM
Copyright ©1999-2017 diyAudio
