6watts RMS output from any gen purpose OPAMPs? and still cheap?
Old 18th August 2012, 10:02 PM   #1
rhythmsandy is offline rhythmsandy
Default 6watts RMS output from any gen purpose OPAMPs? and still cheap?
I want to drive 2 inch full range speaker with 8 ohms 10 watts for pc audio application. Is there any general purpose OPAMP which can do the job instead of going to a power amp. When i disect a Altec lansing speakers I see opamps instead of power amps. Can anybody suggest some good quality opamps does the job? can you please suggest few for this purpose...
Old 18th August 2012, 10:09 PM   #2
jcx is offline jcx  United States
for a linear Class AB amp the best you can do is 70% efficiency - so you need to get rid of at least 3 W per channel - really requires a package designed for heat removal, added heat sink or lots of area of heavy Cu PCB plane attached to special heat conducting features on the chip
Class D switching chips can manage with less heatsinking due to higher effeicieny - can be over 90%
Old 18th August 2012, 10:19 PM   #3
anyway ill add the heatsink for it but some say that opa2134 should do the job but I think its output current is just 35mA so thought if some other opamps should do the job..
Old 18th August 2012, 10:39 PM   #4
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
You want a chipamp, not an op-amp. Countless options here.
Old 18th August 2012, 10:56 PM   #5
but i see most of the 2 channel desktop pc speakers using opamps instead of chipamps... they are driven with single supply 12v and 1 amp adapter. I havent completely break the altechlansing 2.1 speaker but I could see two 16 pin DIP opamps there but there is a small heatsink plates kept on top of it and i ve touched it they get slightly hot while playing at full volume...
Old 18th August 2012, 11:18 PM   #6
Andrew Eckhardt is offline Andrew Eckhardt  United States
You'll probably find it's actually something like this rather than an opamp, unless there are some power transistors hidden somewhere (a couple full bridges worth would be hard to miss):
TEA2025B STMicroelectronics | 497-3991-5-ND | DigiKey
Old 19th August 2012, 03:58 AM   #7
DUG is offline DUG  Canada
If these are like the ones you mentioned with an "op-amp" then I have some information on the ones that I have and took a look inside.
They were listed on the box as 180W pmpo (don't get me started on that discussion)
I looked up the DIP amp in them and found a 1W (total RMS power) @10% distortion amp.
They are what they are: $9 cheapos
I use them at work, keep away from the 10% distortion levels and they work fine. Certainly good enough for cheap headphones.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 19th August 2012, 03:59 AM   #8
forgot pix
Old 19th August 2012, 11:49 AM   #9
how about AD815 as power amp for the 2 inch speakers?
Old 19th August 2012, 01:34 PM   #10
Why are you insisting on an op-amp? There are countless chipamps better suited for this....
AN7135-CM
AN17820B
AN5275
TDA7266SA
TDA7365
TDA7297
TDA7266
STA540SAN
TPA1517NE
AN17808B
AN5276
TDA7297SA
TDA7263
TDA2009A
LA42102-E
TDA7372A
LA4450-E
LA4625-E
TFA9843AJ/N1,112
TDA8946AJ/N2,112
TDA8944AJ/N2,112
AN5277
AN7125
TDA7057AQ/N2,112
TFA9842BJ/N1,112
TFA9843BJ/N1,112
TDA8946J/N1,112
TDA8944J/N1,112
TFA9800J/N1,112
TFA9842AJ/N1,112
LM4752T/NOPB
LM4755T/NOPB
TDA2007A
TA8216HQ(5)
TA8246AHQ(5)
TDA7263M
TDA7372B
TDA7499
.... just to name a few.
6watts RMS output from any gen purpose OPAMPs? and still cheap?Hide this!Advertise here!
Purpose of Capacitors Around Output MOSFET's?? Ron AKA Solid State 8 9th October 2011 05:29 PM
Purpose of opamps on a 3886 board? uzernaam Chip Amps 3 23rd October 2010 05:55 PM
Opamps OPA551 and LM6171 for sale cheap lgreen Swap Meet 1 10th December 2009 04:51 PM
What is the purpose of resistive load at line output trans? commstech Tubes / Valves 4 11th September 2009 04:34 PM
anyone know the RMS output of an ipod? gain Digital Line Level 70 1st November 2008 07:26 AM
Copyright ©1999-2017 diyAudio
