wima or metalized film cap for .1uf input cap?
Old 18th August 2012, 09:10 PM   #1
rhythmsandy is offline rhythmsandy
Default wima or metalized film cap for .1uf input cap?
DIY AMP Board TDA7850 4X50W 4 Channel Car Audio Amplifier Board 12V AV Interface Picture - More Detailed Picture about DIY AMP Board TDA7850 4X50W 4 Channel Car Audio Amplifier Board 12V AV Interface Picture in Amplifier from Honesty Shenzhen Co.Ltd
in the above amp does the quality change when the input cap is wima or some auricap of any film cap. Which is more better in terms of sound quality.
Old 19th August 2012, 05:11 AM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Generally, film caps are better because of their electrical/mechanical properties, but the only way to really know is to listen to different caps for yourself. You may be surprised to find out that you can't hear much of a difference between different kinds of caps. In the end, it all comes down to your personal preference anyway
Brian
Old 21st August 2012, 05:11 AM   #3
gmphadte is offline gmphadte  India
Go for some better sounding amps, and not chip/car as the preceding word. Then go for some good audiophile speaker and then try using a mass mfd cap against an audio purpose cap.
Gajanan Phadte
Old 22nd August 2012, 01:37 PM   #4
Arty is offline Arty
to sum it up, within Your project it makes no difference what You use.
Wima is never bad choice.
Old 22nd August 2012, 02:21 PM   #5
suntechnik is offline suntechnik  Russian Federation
Very subjective but metal foil capacitors are the best in signal path Duelund Jensen etc
for solid state applications low voltage electrolytic caps are good too like Nichicon Muse Elna Silmic (Black Gate)
I am avoiding metallized film caps imho Elna seriously outperforms Mundorf Silver oil in terms of sonic transparency
YMMV of course
Old 23rd August 2012, 09:43 AM   #6
R.I.P.
metalised are the cheapest of the film capacitors.
Generally they are perfect for the duty they have to perform, even audio.
Foil caps are more expensive and more bulky. There is a lot of anecdotal evidence that they can perform better than metalised for AC coupling in audio.
I would not use foil for any other duty, except polystyrene in filters. As far as I know polystyrene are only made as foil in film.
regards Andrew T.
Old 23rd August 2012, 10:27 AM   #7
YMMV of course
in which part of the circuit does elna outperforms Mundorf Silver oil? Input cap?
which version of elna are you talking about bipolar elna?
Old 23rd August 2012, 01:11 PM   #8
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
While I've no experience with the diy amp board you specifiy, I can say that changing the input coupling cap. is usually audible. Those caps. generally regarded as the very best, VCap Teflon film, and Jensen Duelund are outrageously expensive. Opinions tend to vary a good deal regarding the caps. occupying the next lower tier. The majority of which can fairly be called, expensive, if not outrageously so. Choosing one can be a vey subjective matter, on top of which there are just too many options to realistically evaluate them all yourself.
Much of your choice will be determined by your budget. To maximize the effectiveness of your budget, you will want to make sure you are specifying a large enough value cap. but not one that's any larger than necessary. Prices rise sigificantly with capacitance value. The formula for determining the optimum value is both simple and readily available on the web. That optimum value will be a function of the input impedance of your amp and your desired low frequency cut-off. However, sacrificing a little bit of the lowest frequencies (with a smaller than optimum capacitance value) may be a worthwhile trade-off, if doing so enables you to afford a capacitor which sounds better across the remaining audible spectrum. Since this is for input coupling, you likely don't need a high-voltage rated cap., assuming that the maximum D.C. offset which might appear at the preamp output is relatively low.
I've found that I can usually hear the benefits of polypoylene film & foil (not metallized foil) construction coupling caps. I consider most of these relatively affordable (by audiophile standards) in values of about 2.2uF or less. Above 2.2uF, the prices can really become attention getting. For 4.7uF and greater capacitance values, I've had very good sonic results with the affordable non-polar Black Gate 'N' and 'NX' series. But these out of production BGs (as far as I've last heard about) are becoming scarce.
Old 24th August 2012, 01:13 AM   #9
lanchile is offline lanchile  United States
lanchile's Avatar
I add to the list too! Wima cap are good, but there are many better caps for inputs, but again for this kind of amp it is not worthy to spent the extra $$
Old 24th August 2012, 02:37 AM   #10
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
generally speaking --- the met film is best used for low current apps and the film-foil better for high current apps (speaker crossover etal). PP and PS are typically very good. -R.Marsh
wima or metalized film cap for .1uf input cap?Hide this!Advertise here!
Replace 25 Year Old Metalized Polycarbonate Film Cap? PreCD Parts 17 31st January 2012 10:42 AM
.47uF output cap to 1uF? phrarod Tubes / Valves 3 19th February 2011 12:27 AM
cmoy with 1uF input cap, DC offset from source still getting through morfic Solid State 11 5th August 2009 01:41 PM
FS : Wima 1.0uF 63V Metalized Cap for CD Mod xtaltech Swap Meet 28 3rd August 2008 03:11 PM
How critical is the 0.1UF to earth cap in the VBIGC Shoog Chip Amps 0 4th February 2004 07:56 PM
