TI AN-1850 circuit with lme49830 and 2sk1530
Old 18th August 2012, 10:22 AM   #1
mantabernd is offline mantabernd  Germany
Default TI AN-1850 circuit with lme49830 and 2sk1530
Hello!
I'm quite new in this forum and I think there's much knowledge so I'd like to ask a few questions about my new project.
I'd like to build a amp with the LME49830. First I thought about taking the IRFP9240/240 mosfets but now I got four pairs for 2SK1530 / 2SJ201 from a friend. The TI Application Note AN-1850 shows an amplifier which uses these mosfets. So has anybody biult this amplifier shown in the app. note? I heard about oscillation problems and a difficult ground routing. I would design a very similar pcb layout as shown in the app. note but not with smd, such with throug hole components.
There's also explained how to route the grounds to the star point, I think I have to be very carefully...
Can anybody give me some tips about this amp? How does it sound with the 2SK1530 / 2SJ201 mosfets? Would it be better to use the irfp ones?
Best regards.
B. Waechter from germany
Old 18th August 2012, 06:30 PM   #2
R.I.P.
do Ti/National actually list those devices as one of the 3 alternatives for that 830 chip?
Start by wiring up just one pair. But before you use them measure and match your devices and source resistors.
regards Andrew T.
Old 19th August 2012, 01:21 PM   #3
Hello Andrew
Thank you for your reply. Yes the 2sk1530 / 2sj201 are recommend by ti/national.
Ok I will only wird one pair first. What do you think is the best was to messure the fets? simply messuring the resistance between the pins? I ve never done this before...
What do you say about the shematic? Is it ok or would you change something?
best regards
Old 19th August 2012, 02:31 PM   #4
R.I.P.
for your first pair you do not need to measure anything.
It's when you get to the next stage (if your ever need more driving power) of paralleling output devices that you need to measure and match.
Go and read the Threads and the websites links that explain about matching source resistors and explain about matching output mosFETs.
regards Andrew T.
TI AN-1850 circuit with lme49830 and 2sk1530Hide this!Advertise here!
BK 1850 Manual fandersen Equipment & Tools 0 11th May 2012 04:58 AM
Perreaux Pmf 1850 ! stoN_Cold Solid State 0 20th November 2007 12:55 PM
1850 folded horns tsc Subwoofers 5 5th May 2006 12:27 PM
free Tina ti circuit sim for crossover design sreten Multi-Way 2 1st February 2006 11:10 PM
