My gainclone ate my mp3 player? - Page 4 - diyAudio
Old 19th August 2012, 05:44 PM   #31
I have come across a few cheap mp3 players, that need a fairly low resistance load to function. They often use the headphone load as part of the filter circuit.
Maybe the player went into protection mode as the output caps charged up.
I always fit a bleeder resistor anyway at the input of any amp.
Are you using a SMPS to power the amp ? Often these outputs will float at about 1/2 mains voltage. then add in the -3000v of static from your hands and poof!
Old 19th August 2012, 07:44 PM   #32
Mooly's Avatar
Good point whizgeek. I've never scoped the output of an MP3 player but what you say makes sense about the low impedance load being needed. There could be all sorts of HF hash there too.
Installing and using LTspice IV. From beginner to advanced.
Old 20th August 2012, 06:35 PM   #33
vputz is offline vputz  United States
Whizgeek: it's not an SMPS, it's a simple toroidal transformer with a diode bridge and caps (a bog-standard "gainclone power supply" as shows up in a number of places).
I'm still puzzled. The silly thing looks like it's operating fine now, but it was completely insensitive to the power switch for about 3-4 days.
Good point on the bleeder resistors too. I'll take a look and edit, although as mentioned it seems to be all happy again. Bizarre.
Old 21st August 2012, 11:36 AM   #34
You are mentioning an UPS in some post. I hope it is sinewave UPS.
Gajanan Phadte
Old 8th October 2012, 10:42 PM   #35
Send a message via AIM to DigitalJunkie
I had the same thing happen years ago with a portable CD player that I used for testing (specifically because it was battery powered,and isolated).
No idea what happened,I can only surmise that somehow DC came out of the amp's input,and cooked the CD players output stage.
Ever since then I've used input caps,purely for DC-blocking,and haven't had any similar issues.
One other good thought is HF crap coming out of the MP3 player. I know my iPod has some noise and crap on the output. Perhaps your amp didn't like being fed some random several-hundered-khz signal. I dunno.
Old 10th October 2012, 05:54 PM   #36
DJ, if you read the thread you will find that the alleged action/question of
did not happen. He made a mistake and then discovered that the Power Amplifier did not damage his Source.
regards Andrew T.
Sent from my desktop computer using a keyboard
Need help with Mp3 player JorgeO Digital Source 3 11th August 2011 05:00 PM
Converting car cd-player into an mp3 player... dionisis84 Car Audio 10 4th November 2006 10:00 PM
MP3 Player mcl Everything Else 1 11th February 2005 08:51 PM
mp3 or wma hard drive mp3 player martin88 Digital Source 2 6th August 2004 10:50 AM
Copyright 1999-2017 diyAudio
