My gainclone ate my mp3 player?
Old 16th August 2012, 07:37 AM   #11
Mooly's Avatar
Might help to see the exact circuit around the input stage.
Suggestions to prevent this kind of problem would include adding a low value series input resistor (say 470ohm) and as suggested AC coupling.
If there is some bizzarre issue then a couple of inverse zeners and series diodes across the input to ground would kill any spikes and have no effect on the audio.
Old 16th August 2012, 07:43 AM   #12
vputz is offline vputz  United States
Headphone jack out. But I'm still mystified. Visually, input ground lines are connected to ground; I'll try to verify electrical connectivity tomorrow (I've had trouble recently with my ratchet crimpers crimping things all the way through the wires, but these appear pretty good). And I'd gotten tens of hours of use out of the amp itself; this definitely seemed connected to "shutdown thump" (which makes it even more puzzling that the O-scope didn't see anything significant).
Ye MP3 player seems pretty fried. Hooking it up to my computer's USB gives me the "USB device not recognized" error; no power that I've found is able to get any response from the thing. Luckily it's a pretty old Sansa e200, so not exactly a spendy device, but it was good for testing.
DigitalJunkie, I'm used to coupling caps being used to smooth power to chips; would have thought they'd interfere with signal if used on the audio input. I see in the audiosector.com instructions that he references protecting the AMP from DC offset, but I never considered protecting the input source.
I'm still weirded out by the lack of any significant voltage spike when connected to the O-scope. Should it make a difference whether speakers are connected? I left the amp at work, so I can check it out a bit more tomorrow...
Old 16th August 2012, 07:50 AM   #13
Mooly's Avatar
Spikes can be hard to see as they are short duration. If they trigger the scope at the start of the sweep then you can easily miss them.
You could perhaps have two inputs to the GC. The direct and a "protected".
Ultimately you have to decide on whether there is a real design issue or fault here or whether it's a "characteristic" that needs to be "designed out" by AC coupling etc
If you posted the circuit it might help (to see the exact input stage) and there are basic tests that might reveal an issue.
Old 16th August 2012, 08:00 AM   #14
percival007 is offline percival007  England
Is there any DC difference between the 0Volts of the Amp and the 0Volts of the mp3 Player supply ?
I think the poster above is alluding to this also.
Old 16th August 2012, 08:13 AM   #15
Mooly's Avatar
Zero volts is an arbitrary point.
For example, the zero volts of an MP3 player is still "its" zero volt point even if you were to connect the MP3 ground to an overhead power line. No current would flow and you could refer to this as "your zero volt reference" point.
A battery powered MP3 player ground will assume the potential of whatever it is connected to.
Its when you connect two points that you assume to be the same potential together and find they are not that you have problems.
If that makes sense
Old 16th August 2012, 01:43 PM   #16
I set the scope to trigger on a change with the trigger point in the middle of the screen, and I could generally see a TEEEENY change.
I hear you on zero reference points; on a completely different project, I was trying to supply a variable voltage from 0-20V (from a "reference ground" and "reference V+" to a third contact. Great, but it turned out that both the "0" and the "20V" were at about 90V and 110V with respect to case ground. Got some interesting zaps figuring that one out.
But not the case here. Here are the kicad schematics I made, using the reference design and the audiosector build instructions as guidelines; the audiosector build recommended changing the resistor I had as R5 (the 1K) on the input for a coupling capacitor if one was needed to protect the amp from a DC offset on input. And as mentioned, it worked and sounded great for hours and hours until this happened...
Old 16th August 2012, 02:25 PM   #17
Mooly's Avatar
Hmmm....
Hard to say for sure. A lot depends on what pin 7 (input) does as the rails rise at power on and collapse at power off. I'm thinking that if one rail collapsed first could there be a "parasitic" pathway through the chip allowing significant voltage to appear on pin 7.
In basic terms if say the supply is 30 volts (30-0-30) then a max of 30ma could be drawn from the 1K worst case and with a direct path to the full rail voltage. Could that zap a player...
Doesn't matter what all the theory and debating of this says... it's happened to you and the player is zapped. Was it the amp ? or just a natural failure of the player.
I can't see any problem AC coupling the input. Try a 4.7uf or 10 uf cap to the left of R4 and R5 junction. Also add another resistor to ground at the input side of the cap to ensure it never floats to a significant voltage if the input were unterminated.
Old 16th August 2012, 04:10 PM   #18
Bah, PCB mill is about to be torn down for a move, but I'll test it with a little hack and add a spot for one in the next revision (I'm trying to get this into a simple one-board kit form for some friends' kids, focus on simplicity rather than audiophile quality).
For my edification, when you say "to the left of R4 and R5 junction, also add another resistor to ground"--why not put it left of R5, between R5 and R4, with R4 taking the role of "another resistor to ground at the input side"?
Still learning (my background is mostly software and microcontrollers, so this signal processing business has me making a lot of silly mistakes).
Old 16th August 2012, 06:50 PM   #19
neutron7 is offline neutron7  Canada
neutron7's Avatar
I don't see how the input from your chipamps could fry anything through the 1k resistor. Even a 30v spike on the chip input could only produce 30ma through the resistor.
What would be able to do something would be a ground differential. That could happen if the mp3 players ground is different from the amplifier. Can you check for a voltage between your amps ground and the ground of your mp3s power supply?
Old 16th August 2012, 07:59 PM   #20
Mooly's Avatar
Like this. The resistor can be around 100K. It adds nothing noise wise because it is shunted by the source impedance as soon as anything is connected. The cap as mentioned can be around 4.7 to 10uf.
A practical point is that the polarity (and an electroylitic is fine... really ) is best determined by measuring the DC voltage across it when no input is connected. Depending on the offsets of the IC the polarity could be either way so fit the caps accordingly. Same applies for your C1.
Also for minimum offset the value of R2 should normally equal R4+R5 so as to equalise the DC bias currents flowing from the two input pins.
My gainclone ate my mp3 player?Hide this!Advertise here!
Need help with Mp3 player JorgeO Digital Source 3 11th August 2011 05:00 PM
Converting car cd-player into an mp3 player... dionisis84 Car Audio 10 4th November 2006 10:00 PM
MP3 Player mcl Everything Else 1 11th February 2005 08:51 PM
mp3 or wma hard drive mp3 player martin88 Digital Source 2 6th August 2004 10:50 AM
Copyright ©1999-2017 diyAudio
