EI with Mundorf or Toroidal with cheap psu caps?
Old 14th August 2012, 03:07 AM   #1
rhythmsandy is offline rhythmsandy
Default EI with Mundorf or Toroidal with cheap psu caps?
I had to make a choice where the toroidal for 300va is costing about 60 dollars and EI is costing about 20 dollars Im thinking to get EI and spend rest for the Mundorf capacitors what do you recommend. Is this combination better or do I need to go with Toroidal with cheaper caps..
Old 14th August 2012, 05:36 AM   #2
I found one capacitor company called as Keltron establishment assisted by Spargue Electromag , Belgium, in 1976. Each capacitor 10000uf/50v is supposed to be 2 USD so i think we can use 6 of them to form 60000uf paralled with two 1000uf elna silmic2 should be fine i believe any opinions please...
Old 14th August 2012, 05:45 AM   #3
googlyone is offline googlyone  Australia
In general an EI transformer will have a much larger magnetic leakage. More so with a cheap one. If you don't mind mucking around with layouts and/or living with some induced hum then go for the EI.
I wouldn't.
But then I would not get hung up on the name printed on a cap. Especially if it purports to be something special for audio. (how does it know it is in an audio system?).
I would go for some solid psu caps, paying particular attention to ripple current rating and overall capacitance.
For my money I would go the torpid and some decent caps - and don't waste your money on branding.
Old 14th August 2012, 05:49 AM   #4
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Not sure i understand the grounds for your question. Toroids have no advantage in an audio PS other than the form factor and the low radiation - only an issue in tight spaces.
The Mlytics, otoh, i find much better sounding than any Japanese cap of current production... and no bypassing is necessary.
Old 14th August 2012, 06:34 AM   #5
what Im thinking of is to use the psu as a saperate chassis and then use the actual amplifier into another box so that I can save alot of money on this
example: an toroidal at 18-0-18 300va will cost around 60 dollars instead I can purchase ei which costs 10 dollars and spend rest on the Mundorf and elna silmic2 for psu. That sounds great I believe...
I accept the EI will induce the magnetic filelds but sonically it will not have any variation if its isolated 4 feet from the actual amplifier I think this should solve the issue isnt it..
Old 14th August 2012, 02:41 PM   #6
R.I.P.
Have you read the Threads on separate mains powered PSU?
There is a big Safety issue when the Protective Earth (PE) is not in the box that you touch and connect to other pieces of equipment.
regards Andrew T.
Old 14th August 2012, 04:08 PM   #7
hmm i think i should stick with the onebox for everything....
EI with Mundorf or Toroidal with cheap psu caps?Hide this!Advertise here!
EI Vs Toroidal transformers pcn Pass Labs 21 11th October 2017 05:10 AM
Kendeil K05 or Mundorf M-Lytic PSU caps Fulci The Lounge 43 1st December 2014 01:32 PM
Preventing the inrush current saturation in a toroidal/EI transformer tauro0221 Power Supplies 111 14th September 2012 05:19 PM
Mundorf "M-LYTIC AG" psu caps for Salas hotrodded blue DCB1 build dvb projekt Group Buys 80 25th October 2010 02:54 PM
F2 PSU with 2 EI transformers? mymindinside Pass Labs 32 4th January 2010 09:39 AM
