Old 14th August 2012, 10:39 AM   #11
zakman35's Avatar
Have you got Ci fitted that is on your circuit ?
Yes Ci is fitted.
Beside of changing the gain of the amp, do i have the option to change Rin from 1K to 0,5 in order to increase the input sensitivity?
Modesty is the art to make others discover how great you are.
Old 14th August 2012, 10:57 AM   #12
Mooly's Avatar
Altering the 1K Rin won't make any audible difference. Levels have to change a lot for our ears to notice, far more than tweaking that 1K will make.
Again on practical matters...
Ci will probably need to be increased in value to compensate for the lower value of the feedback resistor. Unless you have something oversized in there anyway. Not doing so will cause the bass response to roll off that bit earlier. So doubling the value would make sense.
A simulation free zone. Design it, build it, test it.
Old 14th August 2012, 09:10 PM   #13
zakman35's Avatar
if i remember correctly, i believe i used the values suggested by the chematic.
ci = 110 μf non polar for the woofer channels.
ci= 10 μf for the tweeter channels.
what values you suggest?
Old 15th August 2012, 05:25 AM   #14
danielwritesbac's Avatar
I like the MooseFet preamp from Classic Valve Design, available as just a board, or with some parts. I have IRF510 fets on mine.
Tools & GuidesClipNipper headroom boostParallel LM1875 pt2ptEasy parallel TDA7293 boardTDA7294 pt2pt ♦ My post has opinion.
Old 15th August 2012, 06:40 AM   #15
Mooly's Avatar
Go to the next preferred values, so that's 220uf (two 470uf's to make bi-polar) and 22uf (or two 47uf for bi-polar).
Old 16th August 2012, 06:26 AM   #16
zakman35's Avatar
Ok, thanks.
Old 17th August 2012, 07:57 AM   #17
zakman35's Avatar
One more question,
how important is the quality of the caps at this position and what caps do you suggest me to use?
Old 17th August 2012, 08:37 AM   #18
CI (NFB cap) is a cap at the inverting input and that is exactly as important as any other input cap. This is a good spot to test drive a couple of different options and to try a tiny bypass cap all for the purpose of finding out what you like best.
Old 17th August 2012, 08:54 AM   #19
zakman35's Avatar
Can you give a place to start?
Nichicon Muse for instance would be an option?
Old 17th August 2012, 09:41 AM   #20
Standard commercial/industrial grade electrolytics works well in this location.
But if you make the electrolytic value too low, then it can have avoidable voltage across it and that voltage gives rise to avoidable distortions.
Make the cap big enough and you don't need fancy priced capacitors.
Transformer based voltage gain + unity gain stage? soundcheck Solid State 2 10th August 2010 02:44 PM
Connecting tube gain stage to LM3886 for guitar amplifier??? How can this be done??? jmillerdoc Chip Amps 6 7th February 2010 03:56 PM
Adding gain to this buffer.... theAnonymous1 Chip Amps 12 3rd August 2007 05:17 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
Copyright ©1999-2013 diyAudio
