Confused with the terms for gainclone. - diyAudio
Old 13th August 2012, 01:47 PM   #1
charas is offline charas  Greece
Default Confused with the terms for gainclone.
I am trying to build a cheap gainclone amp but i am confused with the terms because i am a newbie.What the followings mean,somebody help please:
Rg,Ri,Rf,Rm,Rz,Rb,Rs and Cs,Vcc,Vee.
Old 13th August 2012, 02:09 PM   #2
Download the National datasheet for the lm3886 (or whatever chipamp you have selected).
Look at the table of components and their uses. Look at the various example schematics.
Refer to a fig no. from that datasheet and ask your questions.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th August 2012, 05:49 AM   #3
Thank you for reply.I manage to solve some of the symbols my self and then i look at lm3886 data.
But my question was a general question and not specific for gainclones.For example what the Rg or Rs or Cs... e.t.c, mean in other schematics too.That was my query and not the lm3886.Thank you anyway.
Old 14th August 2012, 06:44 AM   #4
sofaspud's Avatar
It's difficult to specify the nomenclature without the accompanying schematic. The best I can do is make semi-educated guesses (since I'm only semi-educated).
Vcc and Vee are easy... those are collector voltage and emitter voltage respectively. Somewhat analogous to the B+ you find in tube circuits ("B" is for battery IIRC, even if there's no battery. It's just a holdover from an earlier time).
More guessing... Rz is probably Zobel resistance, Rs and Cs refer to the source. Ri refers to input resistance, Rf is feedback resistance.
'Twas good advice to look at a datasheet circuit that includes a table of components and functions.
and Rm and Rs could well be mute and standby... the schematic should make it clear to you which it is.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 14th August 2012, 11:37 AM   #5
Everybody calls them different.
There is no universal standard.
Except for units of measurement. eg.
V = Volts
A = Amperes.
If you have specific schematic then post that. But calling up any combination of letters tells us effectively nothing.
regards Andrew T.
Old 14th August 2012, 11:43 AM   #6
Thank you.This is the answer i was looking for those symbols.And you are correct.In tube amps schematics things are way simpler.
Resource - Laymans terms nathanjh13 Everything Else 0 27th June 2011 09:55 AM
some doubts about technical terms used with speakers. knairkuttan Subwoofers 5 5th May 2010 07:39 PM
DCX 2496 question laymans terms (aka ignorant mans terms) cmckasty Digital Line Level 1 11th May 2005 03:03 AM
Lobbing What is it in layman's terms? mrteleportal Multi-Way 5 24th November 2004 10:00 AM
Copyright 1999-2017 diyAudio
