LM3886 power consumption in idle/mute mode
Old 12th August 2012, 05:51 AM   #1
soda74 is offline soda74  Germany
Default LM3886 power consumption in idle/mute mode
Hello together!
Since the forum and google search did help, here is my current issue:
I measure a power consumption of about 2.6W (mute on) and 2.7W (idle) for one LM3886 in my diy amp. The measurement includes the losses in the psu. The psu provides +/-25V=.
Is 2.7W a normal value?
Redards.
Old 12th August 2012, 06:42 AM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
What does it say in the datasheet?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 12th August 2012, 06:55 AM   #3
The datasheet gives you all information about the maximum power consumption/output/dissipation an how to calculate the correct heatsink but it was no help (for me) to figure out the power consumption in idle/mute mode.
Old 12th August 2012, 07:02 AM   #4
pinkmouse's Avatar
Oh, okay, I must be mistaken. 2.6W does sound a tad on the high side, but I suspect most of that is in the PSU. Can you take a measurement of just the chip?
Old 12th August 2012, 07:43 AM   #5
Unfortunately it is not mainly the psu. The losses in the psu should be minimal compared to the consumption of the power stage.
The setup:
1x psu, 1x microcontroller+mixer, 1xpower-amp with 3xlm3886.
The measuements I already made:
- The psu+microcontroller-board alone: 6.85W
- All connected, mute on: 14.65W
- All connected, mute off: 15.0W
- All connected, mute disconnected*: 14,65W
*the mute is switched by the micro.
This results in approx. 2.6W-2.7W per lm3886.
The schematic is mainly the basic datasheet suggestion.
The ripple voltage of the psu is <=200mV (peak-peak) for the +rail and <=120mV for the -rail while playing music at low volume @+/-26V.
Old 12th August 2012, 07:53 AM   #6
Mooly's Avatar
Originally Posted by soda74 View Post
Hello together!
Redards.
Sounds very reasonable. 2.7watts and a 50 volt supply is around 54ma. The data sheet say 50ma as typical and 85ma as a max so its spot on.
Is that what you mean
Old 12th August 2012, 08:06 AM   #7
Thanks a lot!
Now I found it too, on page 4 electrical characteristics (what a surprise!):
I+ (Note 4) Total Quiescent Power Supply Current VCM = 0V, Vo = 0V, Io = 0A 50 85 mA (max)
I am sorry for that unnecessary thread! Sometimes you do not see the wood for the trees. :-/
Old 12th August 2012, 08:07 AM   #8
Mooly's Avatar
No problem
Old 12th August 2012, 09:10 AM   #9
pinkmouse's Avatar
I'm glad you found it. I had in my head 40mA, but wasn't certain enough to quote that.
Old 12th August 2012, 12:15 PM   #10
R.I.P.
That quiescent current stated in the specification is for normal no-signal operating condition.
I cannot see a specification value for current when in mute mode.
When I look at the mute circuit on p7, it appears that the mute only attenuates the gain of the input stages. It does not show any connections to the power stages. That's where the big current consumption will be. The earlier stages will probably be more like opamps in current consumption.
regards Andrew T.
LM3886 power consumption in idle/mute modeHide this!Advertise here!
need LM1876 mute mode and standby mode help JozzaG Chip Amps 21 19th January 2012 05:28 PM
Idle power consumption noah katz Class D 7 31st October 2011 08:01 AM
lm3886 no mute rtill Chip Amps 21 29th August 2009 05:43 AM
LM3886, power caps, input resistors, mute, and Cm. mudihan Chip Amps 3 21st December 2007 09:23 AM
LM3886 Mute richie00boy Chip Amps 6 18th August 2004 11:26 AM
