Old 13th August 2012, 08:01 AM   #11
I'm testing a new amp using LM3886 and I've done the current measurement running idle (no input signal):
I = 40mA (powered using +15V and -15V)
Old 13th August 2012, 11:03 AM   #12
Well inside the specification limits.
And possibly just 10% to 20% above the typical stats stated by National.
Old 13th August 2012, 03:26 PM   #13
Could be the power supply; mine was +15V and -15V for 40mA, in the specs V+ = +28V, V− = −28V
Old 13th August 2012, 07:00 PM   #14
look at the datasheet.
It shows a plot of current vs Vsupply.
@ +-15V it shows typical @ ~35mA depending on Tj.
Old 13th August 2012, 07:03 PM   #15
Electrons are yellow and more is better!
peranders's Avatar
soda74, HOW are you measuring this? ON the mains side? Voltage times Ampere? This will be VA, not watts.
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 13th August 2012, 07:14 PM   #16
The mA spec is on the LV side of the transformer, after being converted to DC.
Old 14th August 2012, 07:22 PM   #17
soda74 is offline soda74  Germany
peranders,
I used a simple energy cost measurement device which shows the effective power (Watts not VA). I disregarded the efficiency of the transformer (~90%) and so on, since I only needed an estimation...
Regards.
need LM1876 mute mode and standby mode help JozzaG Chip Amps 21 19th January 2012 05:28 PM
Idle power consumption noah katz Class D 7 31st October 2011 08:01 AM
lm3886 no mute rtill Chip Amps 21 29th August 2009 05:43 AM
LM3886, power caps, input resistors, mute, and Cm. mudihan Chip Amps 3 21st December 2007 09:23 AM
LM3886 Mute richie00boy Chip Amps 6 18th August 2004 11:26 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
