A grounding question for multiple enclosures - diyAudio
Old 12th August 2012, 12:44 AM   #1
Default A grounding question for multiple enclosures
The setup I have so far.....
240v supply to my PSU case. The case is grounded to mains ground. The PSU feeds an amp enclosure via a 4 pin din type connector. The four pin connector carries +25v, -25v, two 0v and the the main earth.
The amp enclosure has a Star Power Ground connected to the main ground via a 10ohm resistor and two back to back diodes. The Star Audio Ground is connected to the Star Power Ground via another 10 ohm resistor in parallel with two back to back diodes.
Everything works fine, no hum, ground loop etc, but if I were to build a pre-amp/DAC in a separate enclosure, what would I do with the Power and Audio grounds in this enclosure?
Another project of mine: (a very big one at that!)
http://www.mp3car.com/vbulletin/show...5-pimping.html
Grounding options with multiple cap's Sebastiaan Solid State 48 16th April 2010 08:10 PM
Grounding for multiple transformers jetbat Power Supplies 4 9th December 2009 11:17 PM
Grounding with separate enclosures CfM Power Supplies 4 28th March 2009 04:12 AM
Grounding with Multiple Power supplies question?? Minion Solid State 12 31st December 2006 12:38 AM
Multiple PCB layout & grounding. MWP Digital Source 5 23rd October 2002 05:12 PM
Copyright 1999-2017 diyAudio
