LM3886 without electrolytic feedback capacitor and (hardly) no DC offset voltage
Old 10th October 2012, 08:51 PM   #51
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by Marc Vi. View Post
Why not use the way I proposed? Marc.
With the LM3886, your solution is probably better.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 10th October 2012, 10:10 PM   #52
Marc Vi is offline Marc Vi  Netherlands
Adjusting the supply voltage on one side in order to trim out the offset voltage is a bad solution for every amplifier.
Marc.
Old 11th October 2012, 08:55 AM   #53
R.I.P.
The output offset should be substantially independent of the supply rail voltages in any opamp style amplifier.
However, a VAS stage without CCS supply/source will change it's Iq when supply voltage changes (both rails changing together), and this changed Iq with push/pull more or less current through the Collector load of the input transistor. This changed collector current will change the offset. This is one of the big disadvantages of a bootstrap feed to the VAS in a P3A (ESP) amplifier.
regards Andrew T.
Old 23rd March 2014, 07:23 AM   #54
0x4452 is offline 0x4452  United States
Marc, I successfully applied your tip in my DIY studio monitor (with LM4766 - another BJT chipamp).
Previously, due to the low feedback resistance (200R and 3k3) in my design, I needed a large feedback capacitor. There was a slight but audible distortion, which is now gone or at least below my threshold .
Schematic here: http://rdimitrov.info/blog/show.php?entry=Minimalistic%20HIFI%20Bi-Amplified%20Speaker%20System
Thanks!
Old 23rd March 2014, 01:52 PM   #55
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
0x4452:
thanks for the link. i found a new band i like - Pink Tomato.
any recommendations?
sorry for being off-topic ...
mlloyd1
LM3886 without electrolytic feedback capacitor and (hardly) no DC offset voltageHide this!Advertise here!
DC offset and gain on GC LM3886 Xerxes75 Chip Amps 19 9th October 2012 10:02 PM
LM3886 - DC offset problem luis.jimenez Chip Amps 22 10th April 2010 11:34 AM
Feedback capacitor to minimize DC offset Rafal Chip Amps 31 15th August 2008 10:22 PM
Same old story LM3886 and DC offset officeboy Chip Amps 11 24th June 2004 02:51 AM
