LM3886 without electrolytic feedback capacitor and (hardly) no DC offset voltage
Old 8th October 2012, 09:00 PM   #41
zakman35 is offline zakman35  Mozambique
Hi Marc, this is more about learning to control - adjust offset (as with your case).
This is my original schematic.
I have remove Cin, Ci & Cc
Rin =10K
Rb=330 R
Old 8th October 2012, 10:03 PM   #42
Marc Vi is offline Marc Vi  Netherlands
Hallo Zakman35,
Don't remove Ci because the input resistance will be dependent on the output resistance of the pre-amplifier and that may change the output offset voltage of the LM3886 quite a lot.
And, if there is an output offset voltage on the pre-amplifier, that output offset voltage will be multiplied by 33 !!
Don't remove Cc because it prevents noise and - if necessarely - oscillation.
Marc.
Old 9th October 2012, 02:57 AM   #43
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by zakman35 View Post
I measure dc voltage directly on the pins of the chip, both rails are exactly the same (+36.2V, -36.2V)
Good. Now, what is the AC (noise content) voltage of both DC rails?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 9th October 2012, 08:17 PM   #44
Ac noise = 0V on both dc rails.
Old 9th October 2012, 08:23 PM   #45
Can we return to the original subject: LM3886 without electrolytic feedback capacitor and (hardly) no DC offset voltage.
Zakman35 can you reply on that and on my last post?
Marc.
Old 9th October 2012, 08:41 PM   #46
I install Ci back again (no changes at offset).
My pre amp (minidsp) is AC coupled at the output, so no dc from there.
I will try tomorrow to install back the Cc cap and report back.
Old 10th October 2012, 02:53 AM   #47
Having eliminated so many other possibilities, I think there's 6mv worth of ground loop.
Old 10th October 2012, 08:06 AM   #48
Anyway, back to the topic.
What about adjusting - reducing positive's rails voltage to trim output offset to approximate 0mv. Is that an acceptable practice in power amps?
Old 10th October 2012, 10:11 AM   #49
Sure. You can run some led's on that rail, and you can add two of 4k7 1/4w bleeder resistors. It will make a very mild difference.
Old 10th October 2012, 11:50 AM   #50
No, No, No, this isn't a solution at all!! (Or I don't understand it)
To trim out a offset voltage of let's say 6 mV, you have adjust the positive rail for a multiple of that. And that reduces your output power and induces distortion much earlier on one flank.
Why not use the way I proposed?
Marc.
LM3886 without electrolytic feedback capacitor and (hardly) no DC offset voltageHide this!Advertise here!
DC offset and gain on GC LM3886 Xerxes75 Chip Amps 19 9th October 2012 10:02 PM
LM3886 - DC offset problem luis.jimenez Chip Amps 22 10th April 2010 11:34 AM
Feedback capacitor to minimize DC offset Rafal Chip Amps 31 15th August 2008 10:22 PM
Same old story LM3886 and DC offset officeboy Chip Amps 11 24th June 2004 02:51 AM
