| Chip Amps Amplifiers based on integrated circuits |
#21 |
Will you try the "true" circuit now?
The pot position mustn't make any difference. |
#22 |
12mVdc of output offset for a complete sweep of the vol pot is considerably better than the 100mV to 200mV of offset changes I have seen in other Direct Coupled implementations.
Cvp, do not become complacent. You must ensure that faults elsewhere do not damage your speakers. Detect DC and correct excessive DC and isolate if outside the correction range is a minimum requirement for a DC coupled implementation. |
#23 |
#24 |
Bob Cordell's book "Designing Audio Power Amplifiers" has a very nice LM3886 design -- he takes advantage of the lower distortion when the inverting input is used. Use a dual FET opamp first as buffer, then as inverter (OPA2604). He also uses another OPA2604 as servo. If you take a look at the documentation for the LM3886 -- specifically AN-1192 you'll get the idea.
Bob demo'd his design at one of the NJAS meetings a couple years back and it sounded very good indeed. He also built in a bit of loop compensation -- |
#25 |
#26 |
#27 | |
To be honest we don't have here a real "Direct Coupled".... there is still the Cin before the pot. PS: In front of the amp will be a Technics SH-GE70 |
#28 |
#29 |
Measurements in normal mode, after 180min listening jazz at normal level for a 20m2 room.
WARM after 180 min L R 3mV 2mV min 0% 3mV 2mV med 25% 1mV 0mV med 50% -2mV -3mV med 75% -8mV -10mV max 100% Note 1: temp went from 29C to 38C Note 2: as before, above is mentioned (in %) the position of the pot, not the value of its resistance |
#30 |
I've redone the measurements with signal at the input after a few hours of listening. Basically the values are the same:
L R 3mV 2mV min 0% 3mV 2mV med 25% 1mV 0mV med 50% -2mV -3mV med 75% -8mV -10mV max 100% I noticed that at max volume the DC offset is fluctuating. Any idea what are acceptable values? |
| LM3886 Power supply | jfnewell1965 | Power Supplies | 25 | 2nd June 2011 03:18 AM |
| +/- 12v regulated power supply review needed | renfrow | Power Supplies | 6 | 26th October 2008 10:35 AM |
| Power supply for LM3886 | brconner | Chip Amps | 7 | 23rd June 2008 01:48 PM |
| Power supply for LM3886 | gcds | Power Supplies | 10 | 24th March 2007 06:32 AM |
| LM3886 Power Supply Schematic? | newbie1 | Chip Amps | 4 | 16th January 2004 01:39 PM |
