| Chip Amps Amplifiers based on integrated circuits |
I want to go with the Silmic2 for the chipamp if anybody has experienced using Silmic2 with LM3886 or 3875 or 4780 do reply with how it was different is it worth the upgrade to silmic2?
#3 |
Is it recommended to use 1000uf/35v silmic2 x 10 pieces in parallel rather than one 10000uf Mundorf AG Mlytic? The reasons are paralleling the caps will reduce the esr by 10 times and the ripple current of each silmic 2 caps is 1.6 Amps and x 10 will be 16 amperes. If I take just Mundorf it gives only 4.8 amps. But i dont have the esr for the silmic2 i believe using this will reduce the esr substantially resulting strong psu.
Does anybody knows the esr of the silmic 2 I couldnt find it in the datasheet. I found this kind of psu system in Aussieamplifiers .. http://www.aussieamplifiers.com/nxv101_2_1.jpg whats your opinion. Which is better in this case? price wise both come to close but ripple current will be pretty high and esr will be pretty low. Im only concerned with the signature of these two caps. If the signature of elna silmic 2 is better then its better to use these as psu caps. The ripple current using in 10 parallel caps is higher than the Mundorf Mlytic HC+ which is phenomenal... but if anybody says to use Silmic 2 as psu it would be great.. On bulk purchase we can get better pricing on silmic2 |
| Elna Silmic II or Elna Cerafine? | rg12 | Parts | 58 | Yesterday 11:24 AM |
| genuine elna silmic ? | sulenta | Chip Amps | 5 | 17th September 2011 11:48 AM |
| Need some Elna Silmic II | Stefanoo | Parts | 6 | 18th November 2008 09:43 AM |
| Elna Silmic/Cerafines | Thomo | Parts | 7 | 6th December 2006 07:35 AM |
| Elna Silmic capacitors | Jules | Swap Meet | 4 | 9th June 2002 04:43 PM |
